I've read several of the responses re: hull fabric--and it's replacement and I wonder why no one has talked about painting the inside hull with a moisture resistent paint. If anyone has any thoughts on this I'd like to hear them Bill
I have residual glue also, but it is hard and firmly adhered to the surface so I bet I could paint overit with a good oil based enamel. I would do a test patch first to be sure i got good cure and adhesion. If i wasn't happy with results, i would try a test patch with exterior latex. I would not be bothered by the texture but would rather enhance it if need be with a loopy roller...much like the non-skid deck treatment.
But I am going to use fabric because it will help with noise inside. Also it should help with the asthetics, softening all the hard surface. But I did like the cleanability of the paint idea. I still may paint the rear quarter birth.
I don't like the floor carpet idea, because it would trap moisture. The fabric designed for liner dries much better. It is thinner and more pliable.
Disclaimer....I have not put my liner up yet, I have just read as much as i can, compared products online, and following forums, so this is just book knowledge. I HAVE installed house floor carpet and vinyl.
