Rick,
Do you have a line drawing for your reefing set up?
I manually run a line thru the inside and outside grommets and tie off. I have two reefing ties on the main.
Do you have your lines run to the cockpit?
I do not and do not have the base plate to attach turning blocks to (at least not yet). I have not rushed that idea because the cabin top does not have much room to attach cleats. If you have cabin top cleats, snap a picture of those too.
Keith,
First, remember that you do not have to have interior finish to sail. Just any structural parts. Get your boat in the water and pull it out after Thanksgiving to finish.
Second, when putting mast up and if you have a roller furling, remember to lubricate all the blocks.
Now that I think of it, you do not have to all the exterior painted to sail. Use the boat for a few months and then finish. It is too hot :cussing: to continue working anyway...
Ed K
26
Keith,
Ed K
26
