Traditional Dinghy
67
Hunter 340 N. CA
About 5 years ago I bought a Zodiac Fastroller inflatable - the one with the pressurized floor and keel. It has been well cared for and fun to putter in, but it's already starting to fall apart. I've recently heard this is not unusual for this model. I'm now considering a new dinghy (if my wife approves) and we're leaning towards a traditional wood or fiberglass one with the added possibility of a sail kit, perhaps something in the 8 to 9 foot range. I'm trying to do some intenet research on different manufacturers, but unfortunately I'm generally coming up empty. I'm not interested in Walker Bay or that style, but that's about all I've found. I know inflatables have a major piece of the market, but traditional dinghys must still be out there. I would apprecaite any leads in terms of manufacturers, names, etc. Thanks!
luvitt
Oct 30, 2008
297
na na na
me too. i will keep an eye on your post. i'm leaning toward a rib just b/c it has a more traditional hull, plus extra stability. I cant even figure out how to google what we are looking for though.
I think one possibility is looking around the marinas. i'm in a big marina, and there are a couple for sale, but still not what i'm looking for. at least you could get some names off the plate maybe?
good luck
Bob V
Mar 13, 2008
235
Catalina 42mkII Lagoon Point
A wide selection
can be found at Gig Harbor boatworks where there make traditional boats out of modern materials. The 10 ft Navigator might be what you are looking for. I have the 14 ft whitehall which is a little on the large size for a tender but I is a real peasure to row or sail and a small electric motor will push it along quite nicely.
http://www.ghboats.com/
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Given the size of your boat, either an 8' or so hard dinghy or if you need a larger one, a nesting dinghy, would be the way to go.
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
Two boats I'd recommend
While the Dyer's are the old traditional dinghy and I'd be proud to own one, the two dinghy's I'd recommend are the Trinka and a fatty knees. The Trinka is built like a tank, very solid boat with great workmanship. You can get two sizes. The fatty knees is a lapstrake design and also a very solid nice boat. Check them out. Not sure where to buy them other than in Noank, Ct. there is a boatyard that sells the Trinka.
Sep 29, 2008
1,976
Catalina 310 #185 Quantico
What is a nesting dinghy?
Been following this quote as I would also like to add a sailing dinghy that would be very easy to tow behind my 310. Would also like a wheel permanently mounted somewhere so that it would be easy to carry back and forth from the dinghy rack.
Oct 22, 2008
3,502
This might be a good, if somewhat expensive solution for you.
It's a Niccols Lite NN10-II nesting dinghy.
Ross
Jun 15, 2004
14,693
In Dave Gerr's book that I just bought he has plans for a dink he calls "Nester". Eleven feet that comes apart and one piece fits inside the other. 135 pounds but each half floats by its self so it can be assembled in the water.
Jun 7, 2004
383
Schock 35 Seattle
I second the motion for the Gig Harbor Dinghy. A good friend has one--it is awesome!
Dec 9, 2006
694
Oday 22 Hickory, NC
I am thinking real hard about making a traditional 'Pram' that is in Edwin Monk's book 16 boat you can build, (Or something close to that name.)
It is built from oak, cedar and mahogany, will probably cost a ton for the wood, but will be something to row adn look at!
Jack
Jul 1, 1998
3,062
I "Third" Gig Harbor dinghy
What makes the Gig Harbor dinghies so exceptional is what you can't see - their light weight. The typical hard shell will weigh quite a bit which make them hard to launch and ship. Gig Harbor uses a process that is used on aircraft which results in MUCH lighter weight fiberglass.
Caution: when asking about price be sure to sit down before you hear the answer.
Every once in a while a used one comes up for sale and this could be a good buying opportunity. A sailing model would be absolutely tops.
Nesting dinghy: I really like this concept but so far I haven't seen one that is what I want - 3 piece that could be used in sections? The other thing I'd want is a light weight one like the Gig Harbor construction.
Ross
Jun 15, 2004
14,693
Re: I "Third" Gig Harbor dinghy
Light weight and three sections gets into the realm of build it yourself with Corecell structrual foam and fiber glass/epoxy systems. Probably 500-750 dollars for 10-12 feet.
Beneteau 323 Annapolis MD
I recall a couple decades ago there was a slick three-section dingy. You could put it together with, or without, the middle section. Sorry, that's as much as my memory recalls.
