Non-skid cleaning
515
Hunter 320 Williamsburg
Does anyone have success cleaning the diamond-shaped non-skid at the edges and corners where grime builds up? I've tried Barkeepers Friend and bleach, to no avail. Thanks.
Jan 3, 2009
821
Marine Trader 34 Where Ever I am
Soft Scrub
Be careful with Soft Scrub. It contains abrasives and bleach and if used improperly can dull your gelcoat or paint and if not rinsed off really, really well it will dull and damage or discolor paint, gelcoat, wood and canvas. Chuck
Sep 20, 2006
2,955
I've had good success with the StarBrite Non-Skid Deck Cleaner. Worked very good in the cockpit area.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
A pressure washer does a pretty good job of cleaning non-skid without chemicals or damage.
Nov 17, 2008
49
Hunter 38 St. Petersburg
We used Starbrite non-skid deck cleaner on our Hunter 38 this past weekend. It cleaned areas of non-skid that we had thought were hopeless, including the cockpit, where there was a lot of ground in dirt.
Gail R
Apr 22, 2009
261
Pearson 34 Freeport, ME
A vote for Star Brite here. Not as chemical-ly as Roll Off.
I've found that squirting it on, spreading it out, and letting the stuff sit on the wet non-skid for a few minutes before scrubbing and hosing down works best to get the most grime off with the least effort.
Jul 16, 2009
9
Oday 32 Center Cockpit Sloop Solomons, MD
Another vote for a quality pressure washer--three weeks ago I asked/received marina permission to PW the entire deck of S/V Beyond_the_Arc (also asked slipmates & neighbors). In two hours (and two tanks of gas!) thirty+ years of dirt and grime were removed and flushed away--water only! Boat looks almost new, the white is white!, the tan non-skid is clearly tan and the blue stripping is beautiful. Waxed & polished the gelcoat and now, almost a month later, she's still beautiful! And for a near-geezer (I was at Woodstock!), I could easily stand and do the work--much easier than the scrub-a-dub I tried in April (to no real success) using many of the aforementioned cleaners.
Just my own experience.
Smooth sailing!
May 20, 2004
151
C&C 26 Ghost Lake, Alberta
Cleaning non-skid
"Tilex" with bleach! Safeways - about $5.
Gets rid of the little black mold spots too!
sam :)
Dec 2, 1999
15,184
Check out most of the non-skid cleaners. They are using oxalic acid as one of the major ingredients. You can make you own cleaner with some boat soap and oxalic acid. It is also good for removing rust from stainless.
