All cleaned up...Check this out!
19
Macgregor 19 Waco, Tx
I read a thread on here a while back that talked about what to clean your boat with. It talked about this stuff called "The works," which is just a wal-mart toilet bowl cleaner. Well I tried it out and trust me it works! Go to this site below and watch the magic happen right before your eyes. This boat had been setting unloved and pretty much abandoned for almost 9 years. I took me a little over a total of 8 hrs on this Newport 28 to get it to almost new condition. You just wet the deck and pour on the cleaner, let it set for a few minutes and throw some elbow grease down like it is going out of style and you have your self a brand spanking new boat practicly. Well here is the site with the slide show... Enjoy!
((http://www.flickr.com/photos/kreed17er/sets/72157617957011024/show/))
Keith
Mac 17
Beneteau 323 Annapolis MD
That looks great, Keith. I take it "The Works" is not caustic?.... I'm holding out for "Boat Magic": spray it on, it would foam up, lift the dirt, dry up and blow away in a 5-knot breeze".
2,288
C30 Event Horizon Port Aransas
I'm going to try it this weekend. What year boat is that newport? It looks like a nicely designed boat.
Jun 30, 2004
446
Hunter 340 St Andrews Bay
Looks great, Taste BAD! While I love magic bullets when it comes to cleaning stuff, "the Works" is for toilet bowl use only and may be too caustic around the lake. Just looked at the bottle: 'Danger: Corrosive-causes skin burns an irreversible eye damage. Harmful if swallowed or absorbed through skin, do not get in eye, on skin, or on clothing. Wear goggles or face shield, protective clothing and rubber gloves..." Since our lake is water source, the DNR, Dept of Sanitation, and Water Board probably would rather you pump the head overboard before you wash this stuff into the water.
On the other hand it does kill staph, salmonella & e. coli
You might have blind bass instead if black bass under you boat now-already cleaned!
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Be careful not to get this stuff on metal or lines... not good for either. :)
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
Now is the time to get some compound and wax on and the the boat will stay looking sharp
Jul 24, 2006
628
Legnos, Starwind, Regal Mystic 30 cutter, 22 trailer sailor, bow rider NEW PORT RICHEY, FL
Clean Boat
Nice job. I hope you did'nt breath the works, it will take your breath away. The active ingredient is acid, don't know which one, muriatic, hydrochloric, or phosphoric. Anyway, water nuetralizes it, so not sure how bad for the water it is?
Now you can further glean your boat with some wet sanding with 600 or 800 or even 1200 grit wet sandpaper, buff then wax it. The work will pay off big time. Hell just wet sanding does wonders. Takes out the little discolorations and stains and some scratches and gives a light shine to the surface/gelcoat.
Mar 24, 2009
19
It is a 1989 Newport 28. I did read the bottle a couple of times and while I was worried there for a moment I made sure that the wind was blowing so that none of the product was inhaled. That and rubber gloves, long sleeves, and pants are all necessary while cleaning for sure. Since it is water soluble I am not to worried about it blinding bass or anything like that. The wet sanding sounds good and I will definitely end up doing that to put the finishing touches on this good looking boat. I did not put the product directly on the teak but instead scrubbed the teak with a deck brush and when it got wet and just that did wonders. What do you guys do to your teak that is quick and easy and that will last one summer? Teak oil, varnish, just cleaner?
7,744
Alden 50 Sarasota, Florida
Sounds like the "dilution is the solution" theory is still alive and practiced. With that attitude, why not dump the holding tank anywhere as well? After all, it's water soluble.
Mar 24, 2009
19
Illusion, what do you use or what would you use to clean some thing like this in the future?
Sep 29, 2008
162
Morgan Out Island 33 Pompano Beach
Toilet bowl cleaners are toxic and could damage the fibreglass...flush with lots of water. Better idea...Soft Scrub, not toxic, no rubber gloves required, not very abrasive...less than polishing compound and does a better job. Bob
Apr 10, 2009
5
2 26 West Point Lake Ga
I use soft scrub on my Chrysler 26 and it seems to work very well,mine sank in her slip about 2 years ago and after we raised her she had mud stains all over her topsides that would not come off with regular cleaners,i picked up some off brand calcium,rust,and lime remover and like magic the mud stains were gone,dont know if its the best stuff for fiberglass but it sure works!
Nathan
luvitt
Oct 30, 2008
297
na na na
the ingredient is hydrochloric acid. i guess you could call it muriatic acid, which is just diluted hydrochloric (i used to be a brick masons tender in my teens). yes it does clean. its also pretty cool when you blow it up! when i was a kid we use to put the works in a 2-liter coke bottle and drop in a certain household metal, put the cap on, shake, and 10-30 seconds later....BOOM!! sounded like a cannon. the coke bottle would stretch enormously sometimes before it blew up. fun!
Tim R.
May 27, 2004
3,626
I have seen muratic acid tear into porcelin if left on for a couple of days. Don't ask how I know this(not boat related)
Dec 27, 2005
500
Hunter 36 Chicago
It also rapidly rusts 1970 HD XLCH motorcycle parts if they're left near an open container of the stuff.
Feb 10, 2009
35
Beneteau Oceanis 461 St Augustine, FL
When I used to dry-sail my J-22 w/o bottom paint, we used to use Oxalic acid (same as Tidy Bowl) to clean and restore the original color of the fiberglass: It took a very small amount of wiping with a sponge soaked w/ the stuff and subsequent rinse w/ fresh water... Worked great... This looks very similar...
The "fiberglass hull cleaning" materials at boating stores also - I think still - contain Oxalic acid. If it were that bad for the environment, I'd have guessed they would have been banned already.
Happy boat cleaning to all ;)
Sailndive
Feb 10, 2009
35
dilution? hmmmm that changes everything.
Not sure if this was directed at me :) I was suggesting that if this stuff was that bad for the environment, it would have been banned from use in a variety of ways; such as, cleaning toilet bowls then flushing the stuff would have been really bad for the treatment plants, using as hull cleaner in -obvious- marine environment would have been prevented, etc, etc...
Remember TBT? When it is proven that a chemical is bad enough, its use is typically controlled or prevented altogether.
I am certainly not an expert chemist or a biologist - perhaps dilution does cause an effective reduction in harmful impact... Perhaps it is dependent on the particular environment you sail in - a lake without much water flow/circulation may be impacted more than the waters with a lot of current or tidal flow.. Just a thought, that's all.... (and I don't own the J-22 anymore anyhow ;) )
Peace :)
Sailndive
Jun 5, 2004
209
- - Eugene, OR
I remember several years ago when I happened by a sailing friend's place while he was cleaning his boat hull with oxalic acid. Some of it was dripping on his trailer and wasn't promptly washed off. It bubbled his trailer paint. Water soluble does not mean harmless. Keep in mind, water is the "universal solvent" -- most things, good and bad, will dissolve in water.
Jim Kolstoe, h23 Kara's Boo
