Updates amd questions on all the repairs
2,288
C30 Event Horizon Port Aransas
As scheduled we put the boat back in the water Saturday. There were no leaks from the through hulls only from the packing gland. I hooked the batteries up, which I took with me so I could maintain them. Finished hooking up the raw water lines and started the engine. After 6 months of sitting it started in half a second and didn't miss a beat. I was very happy about that. The rebuilt water pump worked great also.
One concern I had was on top of the engine where the water hose hooks up to the mixing elbow there didn't seem to be enough room to double clamp and on the engine where that hose hooked also?
I installed the GFO packing so I hand tightened it until it was leaking like 3 or 4 drops a second. I didn't have the break in instructions but I knew I had to go slow with it. After motoring it, I tightened it one flat on the packing nut to where it was dripping once per 5 or 10 seconds at rest.
The original prop had a broken ear, bent blade and was loose on the shaft when I pulled it from the water. It was a 12LH10. It would do 4 knots or so with that prop. I changed it to a 12LH11, now it does between 5 and 6 knots depending on the wind. I don't exactly trust that knot meter so I am going to have to check it with gps later. Same knot meter though.
It was a very uneventful 30 minute troll in the intracoastal.
The depth meter would go from 15' to 2' to 5' to 14' in seconds sometimes, what is the deal with that?
I did end up having a key way cut in the shaft and coupling where before I had a pin through a hole.
I had no paint left over from going back and re-fairing the keel in fiberglass and installing the thorough hulls. So there was that little spot on the bottom of the keel where it sat on the blocks. I spent $83 for a quart of Micron CSC. The guys in the yard siad, "we'll just give you some", but it wasn't the same so I didn't know how compatible it would be so I just sucked it up and used the $83 quart. What killed me was 6months ago I got 2 gallons for $60 each becasue west marine was going out of business. Then I read on the can it needs 16 hours before you put it int he water. I waited 2 hours and then put it back it. I should have left it unpainted and saved the money. I don't even know if that paint will fully cure under the water. I'll find out when I dive under it this summer.
I am tied up at the boatyard dock. The Corpus Christi marina where I wanted to go is having a boat show next weekend so I hear they are getting $2000 for a slip for the weekend from exibitors. So I may be hanging out on the yards docks a little longer. I'll go check it out though to see if they can put me up on the old docks.
Nice work, Hermit
Congratulations on all the "done good" stuff. Enjoy.:)
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
It floats! Congratulations. It is a nice feeling to see your boat all cleaned up and in the water. No name on the transom yet? I could have sworn you had decided on one.
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Good work
Hermit,
Lots of us have watched as you have gone through this process. Seems to me that you have been able to pretty well seperate good advice from bad, and to do nice work as you went along. Not only does this give one a nice sense of accomplishment, it also makes you very familiar with your boat and systems. And at some point this will be very valuable.
Congrats on a nice job. Now go and sail the boat and enjoy the fruits of your labors.
RECESS
Dec 20, 2003
1,509
Catalina 27 . St. Mary's Georgia
I am there with you Scott. I have spent my whole weekend working on the boat and trailer. I am just finishing painting the accent stripe on the boat. Spent 4 hours making my trailer extension yesterday with a friend. it will slide out an additional 10 feet at the ramp leaving my tires out of the muck. Plasma cutters are a damn nice tool!
What fish finder/ Depth sounder are you using?
2,288
Recess- It's just the stock depth sounder. I did get some bottom paint on the ducer, maybe that's why it is acting funny. It worked just fine on the wayto the yard. Did you shoot that paint on? I see you have a good sized air compressor to handle such a job. I would like to paint the topsides black on mine but fear the heat factor.I have a Miller Spectrum 2050 plasma cutter and I just haven't found it that useful for the stuff I do. I have descent sized band saw that I cut most of my steel with. I would gladly trade the plasma for a good rib with a 10 hp.
BobM-the name we decided on is Event Horizon. It's where time doesn't matter any more when going into a black hole. Anyway we haven't decided on the lettering yet and still need to finish the coast gaurd registration. I have to consult my wife before I have the vinyl letters cut.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Sounds like it could be a loose connection too... check to see that you've got a good solid ground on the instruments. :)
RECESS
Dec 20, 2003
1,509
It was rolled on. You must have a specialized sprayer to spray perfection. Even then I have heard the sprayer tips getting clogged. Rolling worked out pretty good. I got just a tad of tiny air bubbles. The hard thing about doing all the owrk yourself is you know where the bodies are buried. I doubt anyone else would noticed the flaws I know are there.
I imagine bottom paint on the transducer could give you problems if it was not evenly applied or had air in the coverage. As good as they shoot through a hull, I would think a clean coating of bottom paint would not mess it up. I have no idea though.
BTW, this is where I ordered my vinyl letters from today. I like their software and it was very reasonably priced.
http://www.speedysigns.com/
2,288
saildog-that was probably it. I haven't hooked up the DC system yet. I haven't checked it so I don't trust it. I just had the wires ran to the battery and wrapped around a bolt on the terminal.
2,288
Thank you Stu and Nice and easy- it is so cool to be able to come here and get expert advice on any boat related subject. For those that have ears to hear there is a lot of knowledge in your heads. I feel pretty good about how all the work turned out, and I know it wouldn't have been as good if I couldn't have came here and asked you guys about it first.
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
Depth Sounder and Congratulations
Depth sounders can be effected by debris in the water, weeds, and air bubbles. If you are going through the wake from another boat for instance they can give you funny readings, also the type of bottom can have an effect, mud versus hard sand. Get out into some clear water with about 20 feet of depth and see if it settles down. Inside the intracoastal you probably have all kinds of things to cause variations.
Congratulations on splashing. A lot of work but now you can kick back at the dock, smoke a victory cigar, and toast a job well done. As you get the canvass up and do some cruising under sail let us know if you have any questions.
dave
I would like to paint the topsides black on mine but fear the heat factor...Event Horizon. ...before I have the vinyl letters cut.
Black won't work for ya - you're right, it'd be too danged hot. A friend asked me yesterday about how I like blue hulls. I said, "Fine as long as the temperature doesn't get over 57 degrees!":) Darker's also harder to keep shiny.
Nice name, got room for it?
When we did our lettering, on the stern only, we found our preferred lettering and fonts and shading and color and took it on a floppy disc to Tap Plastics, who then made it up on one sheet, and then we mounted it. Much easier than individual letters. The PO had taken the old name off because he wanted to use it for his new trawler, and we liked the name on the transom better than on the aft hull sides 'cuz we think big lettering there makes the boat look too stubby and takes away from the lines -- see my photo on the avatar - I like the long clean hull.
Oct 22, 2008
3,502
I'd also point out that dark blue and black hulls are harder to spot at night and tend to show dirt, dust and every dent and ding in the hull. :)
2,288
Stu-what's a floppy disc? Is that like an 8 track?
I like when they CNC the vinyl letters on one sheet too. I would never get it on there straight if they didn't. It would end up looking like a 3rd grade art project.
I secured a slip today and will be taking the 8 hour trip back to the Corpus Christi bay tomorrow. It may not take as long now that the boat goes faster.
I think I want to paint my boat. I tried the polishing technique again. I ran out of 3M superduty compound before I even got close to finished. So I didn't even try using the finness it. It seemed like only the spots that were repaired with new gel coat really wanted to get glossy. I tried to polish the boot stripe area real well all the way around just in case there is any way to do it while it's in the water. I put two coats of collonite wax on it and called it quits.
RECESS
Dec 20, 2003
1,509
Scott
I have been pleased with the result from Interlux Perfection paint. If I had it to do over again, I would chose a different two part epoxy marine paint just because you cannot wax and machine buff Perfection. Hand buffing with only a few waxes that are compatible.
BobM
Jun 10, 2004
3,269
Vote for polyglow instead of paint
Hermit,
Before painting consider just polishing the hull clean and putting on polyglow. It will be the best $65 you ever spent if you want a shiny hull without using a paint brush or buffing. See the attached photo after a single fresh coat last season. As a bonus, most of the scuffs from the previous year were in the polyglow, not the hull and just cleaned off with scotch brite. I touched up those areas then applied one full coat.
VERY appropriate name.
Bob
492
Oday 222 Mt. Pleasant, SC
I'm getting ready to paint my boat a dark blue. It's about 1 shade lighter than flag blue. Hopefully it'll be liveable. When I bought the boat it had faded black paint, but I liked the way it looked dark. I was wanting to paint it red, but my wife convinced me that was a stupid idea.:D
2,288
The only hesitation I have with polyglo is once you do it you are committed and can't go back. The same way painting is.
1,096
CS 30 Toronto
Time will tell
Wait a year or two and see if you still like it!
Many of our members in the club had it on a few years back and sworn by it then. A good number of them has since remove it and gone back to waxing quietly.:confused: The coating easily scratches and yellow due to UV.
I stayed with buffing with Aguabuff 2000 a few years ago, Use Mothers Canuba hard car wax, and Interlux UV protectant wax sealer once in the spring. The reflection of the hull still read newspaper.
I am old fashion but thats just me.
Alex
