I am in the process of changing my sea strainer from the little plastic OEM one to a Perko Bronze much larger unit. The original one was threaded directly to the thru hull. This one has to be mounted vertically. I need to add about 10" of new hose. I was looking at Marine rated Buna-N Rubber coolant and Fuel hose through McMaster Carr.
http://www.mcmaster.com/#5727k12/=1cywml
Is there any drawbacks to this type of hose for salt water?
Marine-Rated Buna-N Rubber Coolant and Fuel Hose
- Use with coolants, fuel, and antifreeze
- Tube: Buna-N
- Cover: Neoprene
- Reinforcement: Nylon screen with a steel wire spiral
- Temperature Range: -20° to +212° F
- Vacuum: 30" Hg @ 72° F
- Color: Black
- Hose Material Meets: USCG 1942F; SAE J1527, Type A2
