delorme lt-20 etrex legend and seaclear II
530
Catalina 22 Kemah,Texas
I need instructions on interfacing either of these for a vista laptop that only has usb no serial ports. the legend has a serial cable with a usb adaptor but isn't recognised by seaclear. thanks in advance. sid:confused:
Jun 2, 2004
5,802
My eTrex with serial cable through a USB adapter works well on this laptop. I have three different packages and all of them "see" the GPS. I do not have Seaclear however. Does your PC recognize the GPS? You can check from "My Computer" or from "Control Panel". If you see the GPS there then I would use "Help" on Seaclear to see if there is a setting. Fugawi, Garmin, and Offshore Lite find the GPS with no settings and no help from me. Of course you first have to have satellite connectivity.
P.S. Also saw this question with answers over on Sailnet.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
You will need a USB to Serial adapter to use the ETrex with Vista. The driver for the USB to serial adapter should allow it to show up as a COM port. You also have to set the serial port interface on the ETrex to NMEA 0183, 4800, 8, N 1. or the computer software won't recognize it.
Mar 8, 2009
530
ok the emulator is installed but it only allows ports 2-99, seaclear looks for com 1 how do i change the settings in seaclear to look on com 2. thanks for your help.
Oct 26, 2005
116
Oday 28 Detroit/Grosse Pointe Park (O'Day 192, O'Day 28)
SeaClear
Tools, Properties, click on Comm tab, change PC Port
