Thanks for the link, Stu.http://www.catalina320.com/ They'd know if anyone would.
You're very welcome.Thanks for the link, Stu.
If you are sailing with the engine off, and the gear in reverse, would you start the engine and then shift into neutral, or switch from reverse to neutral while still under sail, before starting the engine ? Could harm be done to the transmission by doing it either way ?
