Okay, spring is just around the corner and I promised myself that I would replace the 34 year old wire in my 25. I do have the schematic, but it's really does not appear to be too complicated without it. With that said, a couple of qustions:
1. Should I stay with the original wire gauge? I know if I go a little bigger, I would draw less.
2. Anyone have a good source for REASONABLE spools of marine grade wire?
3. I'm thinking of adding a single solar panel to keep a charge to the battery. The boat is moored and I figure I need at least an 8 watt panel. Any suggestions for a regulator (or for a solar panel).
Thanks in advance.
Thanks in advance.
