My buddy’s 2000 Beneteau 42, center cockpit, fixed dodger, cruiser has a leak in the starboard forward water tank. We’ve eliminated all hoses and stuff since they all come out of the top of the tank and are easily seen. The tank slowly leaks to the bilge and we’ve eliminated other water sources by dying the water and having the dyed water show up.. This happens with the water pressure turned off or on. The water shows up in the forward limber hole in the liner structure. We are pretty sure that the leak is in the tank itself, which is molded into the liner and has a lid glued onto the ledge in the top of the molded tank. The lid is not leaking. Beneteau confirms that the top of the tank can be removed if carefully pried off and can be reused after cleaning. They cannot tell us what is holding it down..
Has anyone had the same problem and how did you deal with it? Is the lid held on with elastomer or resin? How did you take the top off? Our plan is to get in the sealant groove and remove what we can see. Then attack the sides with a pry tool and possibly a heat gun to get the sticky to release.. ??
The picture is the top of the tank, looking forward on the starboard side, bunk support board removed. The boat is in Oriental NC (many hours away) , and we are trying to get a grip on how to get the top off before we get there.
