Tohatsu recently replaced my gas line, under warranty, because of a defective primer bulb. The new, much thicker and grey gas line, has the primer bulb at the gas tank end of the fuel line. This presents the problem of the motor fitting not being able to fit through the gas boot and the inconvenience of the primer bulb at the gas tank end rather than between the motor and the transom. Is there a reason for this? Can I change the fittings as well as the direction of the primer bulb? Thanks...
>>ron<<
S/V Serenity
>>ron<<
S/V Serenity
