The JB welded "through hull" was a glassed in threaded pipe. It was done by the factory like that, it has no mushroom head.(the factory didn't JBweld it, but they glassed in a pipe) They put it in at an angle to the hull. I cut it out with a grinder/sander to prepare to install a real through hull. However since the hole is angled it seems easier to just glass this hole up and redrill a hole straight through the hull. There is another through hull that was done the same way;it is the sink drain. I think that one needs to be moved to make it easier to get to and away from the muffler so I will have more room for the backing plate.
It looks like I will be able to use the holes from the other 3 through hulls, raw water feed, marine AC, head pump out. But these two holes will need to be glassed in or plugged up.
What is the best way to fill in the holes? Do I need to feather out the outside and then fill it in with layers of cloth or can I just fill in the hole somehow?
