Dave,What is the bridge clearance for the oday 222.
tks.
Dave.
I really don't think so. If your mast is Z-Spar with internal halyards like mine, definitely not. O'Day used about three different mast companies, so I'm told. I think that all the masts and spars were the same size for the design of this boat. Measure your mast, then measure down from the Tabernacle to the waterline and that will give you an exact measurement. I know of a guy who lives in Essex CT. that had the same problem. He knew that an O'Day 22 short mast stubby keel boat could fit under this certain fixed bridge in the area in which he sails, because he had an O'Day 22 before he bought his O'Day 23. He wasn't happy with the 23, so he gave it to his son and bought an O'Day 22 similar to the one he had. He's very happy with it. Perhaps there is a yacht club on the other side of this bridge that you could join and moor your boat there. That's what I'd do.Should have told you this in the first post. I must be able to clear a fixed bridge that is
28' 6" at mean low tide.
Will a 222 make it?
.....according to my manual. The 222 is proportionally larger so I doubt you will clear a 28' 6" bridge. If you can locate your manual, or even the specs from a brochure, it may indicate the height of the boat above the waterline.Should have told you this in the first post. I must be able to clear a fixed bridge that is
Will a 222 make it?
