Has anyone ever placed a measuring system on the anchor rode measure and record the actual strain on the system in a storm? If they have what were the results?
Ross, before I decided to anchor out in Ike, I did some calculations. Found out that in winds 130 knots hitting a solid flat surface would put a force of about 52lbs on it. So I then calculated that I have at max, 50 sqr feet of surface exposed stern to (I was testing the theory that you don't swing on anchor when stern to). Then I figured another 10 sqr feet of the mast exposed. Then figured that neither of each is flat so only take about 80% of that and I figured that was actually a safe number was it mostlikely would be a lot less.
So, in 130 knots, which of course if I did get up to 130 knots, it wouldn't be 130 at water level, I came up with the following presure on my anchor system:
mast and rigging: 800 lbs
stern and cockpit: 2080 lbs.
total : 2880 lbs.
Now when I was out there and had to pull on the rode, it wasn't anywhere near that much so my numbers were very safe indeed. I figure it was about 600-700 lbs of force on the rode. I come up with this number as I could mess with the bridle when the pressure was in half, but I couldn't budge it when all the force was on one line.
Of course, when you anchor from the bow, the pressure veries as you swing and expose more hull.
