Coffee on board
May 7, 2012
1,633
Hunter e33 Maple Bay, BC
I will admit that brewing a cup of coffee with the Aeropress is a bit of an arduous procedure and it is messy. But if I follow these instruction, it is my experience that a very good cup of coffee results. Coffee preparation and consuming methods vary widely and are always influenced by personal tastes.
How to make the Ultimate Aeropress Coffee
2,259
I do like good coffee, and over the decades have found that many (most?) independent coffee shops will serve a tasty brew that meets my basic criteria of being "BTS" -- better than Starbucks. I hate that burnt taste of that chain's products.
For the boat though, I want speed and something 'adequate'-- and the interesting thing is that anyone wandering the dock in the morning needing a refill for their cup always likes my chosen boat brew... :)
"Medaglia D'oro® Espresso Instant Coffee"
:cool:
169
Hunter 410 MDR
So I'll come over to any of your boats for coffees, but..
Underway, I actually, even most of the time, make instant. No messy grinds, faster, easier. Coffee maker may work on a gimbled stove, then theres the power needed, cleaning the French press is a hassle. Not to mention instant by volume takes up less room per cup in storage.
If at the dock, yea a Coffee maker and s good fresh grind is lovely, drinking that coffee is more of an event rather than a needed survival ration when battling the elements. My take only.
Sep 27, 2020
25
Tartan, Compac T27, CP19 Stuart
Funny, I switched to a French press years ago because it was easier to keep clean. No filters to worry about. Stainless carafe keeps coffee hot, doesn't break, only one step. Pour hot water, drink coffee.
As for grounds: I like fresh ground but don't always do it. Easy goto is Dunkin Donuts (from the shop not the grocery, there is a difference). I like many classier beans and enjoy trying a local grind. Best I can remember was Black Water Bakery house brand in Cambridge Maryland.
Nov 6, 2020
629
Mariner 36 California
Oh man! I'm definitely in the coffee nerd category. I ditched all the fancy coffee machines, french presses (way overhyped in my opinion) percolators (even worse) etc...etc...I have settled on pour over method after a couple of decades of experimenting. The problem is that most of them suck because the size of the hole in the pour over maker has a huge difference in the quality of the cup of coffee. It doesnt have to off by much to make a significant difference between a fantastic cup of coffee and a 'meh' cup of coffee. Also, i grind my coffee fresh with a burr cone coffee grinder. Mt Elgon in Uganda produces the best coffee on Earth as far as i'm concerned and that i have ever had, although the specific location does make a difference.
I have a induction HOB that heats enough water for coffee or tea in about two minutes and works great from the inverter. I'm becoming a big fan of electric kettle though. Heats water just as quick.
Nov 6, 2020
629
If you really enjoy (not just like) coffee, grinding beans just before brewing makes a big difference and takes only a minute or two with a small hand grinder if you are making just a cup or two at a time.
I will gladly suffer being called a nerd if that's what it takes to enjoy the difference.
Here is a reasonable hand grinder for anything but espresso.
Amazon.com
I have one of these on board in case the main grinder fails :D It makes fantastic ground coffee but will give your hand a serious workout.
You can find them waaaay cheaper than the linked one, but just to show it.
  • Wow
