Coffee on board
Jun 11, 2004
1,952
Oday 31 Redondo Beach
I drink 2-3 cups/day. I like coffee enough to buy the hipster stuff, but I'm not enough of a nerd to grind my own.
How about you?
If you really enjoy (not just like) coffee, grinding beans just before brewing makes a big difference and takes only a minute or two with a small hand grinder if you are making just a cup or two at a time.
I will gladly suffer being called a nerd if that's what it takes to enjoy the difference.
Here is a reasonable hand grinder for anything but espresso.
Amazon.com
I use a #6 Melitta filter into a ss thermos, makes more than six cups, stays hot all day, pre-ground coffee usually Tim Horton's dark, I'm Canadian... I make it strong, recognizing it ain't perfect. Sometimes I'd buy "better" coffee, too, jut to treat myself. At home I use it too along with a cup of espresso from our machine (which unfortunately just broke!). I used a French press for a while, but it was far messier to clean than just dumping the used full filter into the trash.
AaronD
Aug 10, 2014
774
Classic Yachts 26 Newberg, OR / Shelton, WA
1 cup - Aeropress Coffee Maker - Original. Best coffee ever but messy to clean.
>1 cup - Melitta Thermal Pour Over. Very good coffee and the thermal carafe keeps the coffee hot not warm but hot for a couple of hours.
Ground beans always.
Amazon.com
:plus: (or +100) to Aeropress.
The Porlex Mini grinder nests inside it - probably not the ideal grinder, but a nice compact travel setup, and it's worked well enough for me. Likely to eventually be replaced with an Outin Fino to save a little more wear on the arthritis in my wrist.
Hot water from stainless tea kettle (keeping the tea drinkers happy as well).
~700w for ~3-4 minutes to boil, so ~50 w/h from the battery bank including inverter losses. Primary backup if batteries are low is a Jetboil (but the right answer there is a little more solar).
Catalina 320 Dana Point
Bailey's is $25 here, I'm currently using his white trash cousin's brew Dempsey's at $9.99. I tell everyone I use it instead of cream because it doesn't need refrigeration. It's got to be healthier than that bodged up coffee "creamer" so many use.
Oddly I have a twenty+ year old glass french press on board that has not broken, rusted or otherwise failed, as expected it's cursed to stay at sea forever like the Dutchman.
  • Ha
Likes: dLj
Jan 4, 2006
7,870
OK, I'll have to confess - I don't know what "that little something extra" is???
It can only be the original Bailey's Irish Cream :
And none of their latest lemony, strawberry, mint flavoured horse-:poop:.
Was once almost thrown off a boat by the hosts for adding Bailey's to my Moroccan Mint Green Tea. What's so wrong with that ?
Nov 6, 2006
10,257
Mr coffee maker with stainless carafe on shore power; drip pot when away from shore power. I like Peets fine ground very dark roast.
Nothing puts a smile on my face as much as a fresh cup when taking the 2 am to 6 am watch.
Likes: BigEasy
Dec 25, 2000
6,071
I've acquired a taste for ice coffee and enjoy it more than when hot. I grind my favorite blend, let it steep overnight in my French press, then in the fridge to chill.
I either grind coffee at home and take it to the boat, or bring the beans and hand grind beans while waiting for water to boil. The best coffee comes from freshly ground beans, No red can Folgers on board. I like medium dark roasted Sumatra beans. Starbucks Pikes Peak roasted beans are fairly good. :biggrin:
I prefer drip coffee. My wife bought me a Fellows coffee maker for the house. It makes very good coffee.
May 29, 2018
693
Canel 25 foot Shiogama, japan
Instant coffee with "a little something extra"
That peculator on the stove used to be used for coffee but now it is just a kettle.
Jan 7, 2011
6,018
Oday 322 East Chicago, IN
I started out boiling water in an enamel camp boiler, and then pouring it over the filter basket of an old drip coffee maker, into a thermos bottle.
Then I tried a French press…boiled water in the camp boiler, and poured it into the press. That worked but the coffee cooled off too fast (and the press was glass).
Now I use a small mocha pot, sit it on the gas stove and make a small batch. I didn’t need 6 cups for just me. So the mocha pot gives me a nice strong cup of coffee, not enough that it gets cold, and I don’t worry about breaking it. I also find it is easier to clean than the French press.
Greg
Setting aside the cuteness of the mocha-pot, how is it different from the percolator we used to see on the stove bubbling and popping water up from the base to the basket of grounds?
The Wear-Ever Aluminum 8 cup Perculator .
  • Sad
Likes: BAD ORCA
Completely different.
Jun 11, 2004
1,952
Once the water has perked up to the brewing basket and then moved back down to the base you are then boiling the brewed coffee (over and over again). Not great for the end product.
edit for clarity: That's with a percolator. A mocha pot pushes water up through the coffee grounds and the brewed coffee goes into a separate section on the top. Kind of like a reverse drip but with some pressure.
145
Catalina 34 mk 1.5 Rockland ME
Simple pour-over for me with an insulated mug. A gooseneck kettle helps with control and with not spilling. I boil the water, then add a splash of cold to hit 200F for brewing; a ratio of 1 oz for every 10 gets you there.
Call me crazy but I prefer the taste of paper-filtered coffee to French Press or screen filters. I do fresh-grind my beans before leaving the house but don’t bother doing so aboard.
In 2025 at the Pacific Northwest Catalina rendezvous I noticed Kelly, from Ullman Sails wandering the docks at sunrise. I asked: Looking for coffee?
Yes I am.
You’ll need to work for it.
Ok
He ground the beans, and I heated the water. We enjoyed a nice brew as the sun began to awaken the marina.
Coffee can be an elixir that brings people together.
Oct 31, 2022
119
Catalina Capri 22, Catalina 42 MKII Huntington
I have a aero press but have never been able to produce a good cup of coffee with it.. not sure what I do wrong.
