Seeking sewing advice
JBP-PA
Apr 29, 2022
838
Jeanneau Tonic 23 Erie, PA
I have a half dozen or so old soldering irons laying around. Would that suffice?
Yes, sure. You can get blades for soldering guns and irons. Temperature control is very handy though. You can burn the edges or it takes too long if you have the wrong temperature. I use a temperature controlled iron for polyester canvas.
Sep 24, 2018
4,821
Catalina 30 MKIII Chicago
I took my sewing machine to a guy that specializes in vintage Singers. While he was tinkering I asked him what model he'd recommend. He managed to make some improvements but the machine still needed more work. He said I didn't owe him anything but I insisted that he take my money. I took my machine home and then gave him a call to inquire about the heavy duty machine. To my surprise, he was willing to do a straight trade. I will likely have a heavier duty machine tomorrow.
On another note, I cut up some PVC I found at the yard to slip over my rigging. It was a perfect fit and only took 20 minutes to free hand cut and install it. It should greatly reduce chafing.
Both materials have their advantages and disadvantages. For your application, I would suggest walking the docks and seeing what others are using for chaff guards. My experience has been using real leather as trim rather than protection from chaff.
Sailrite - Real Leather vs. Faux Leather: Which Is Right for Your DIY Projects?
I rarely see chafe protection in this area. I remember when I was learning to ski as a kid, the gloves with a leather palm held up far better to the tow ropes than synthetic materials
Who told you, that it had to be done in one seam?
you can sew one side, then fold it over and finish the job, no slipping
Good Point!
You can make a cutting blade for the ~ 100W irons by bending a coat hanger, hammering the central arc flat, and shaping with a file. You can also buy just the blade. I did this for years, and it was OK, but the commercial hot knife is much better. Faster heating, better control, better ergonomics.
I'd get a palm and hand-sew it. A hand awl may be useful for starting the holes. (Better than a stitching awl- I have several and I have not used them, for the most part, in 20 years).
Personally, I would go the laminated patch route. Much stronger.
Noted. Most of my old irons are 40w. I will look into a hot knife
I actually grabbed a premade chafe protector from my parts pile for this exact purpose. Unfortunately, I could only fine one. I would need 2-4 to do this job
Another option would be heavy webbing of another type (polyester). Heal seal the cut edges (need that hot knife!).
I actually bought some for this exact purpose! I picked up a few different materials to see what would work
Jan 7, 2011
6,018
Oday 322 East Chicago, IN
Good Point!
What machine did you trade in and what did you get?
I was considering getting a sewing machine to restitch my sail cover, make some hatch shade covers, etc.
I saw this singer on eBay and may a bid, not really expecting to win…but I did. Singer 4411 Heavy Duty
It certainly is no Sailrite, but for my miscellaneous jobs, she does ok. I can sew through several layers of sail cloth or sunbrella. I even stitched a few layers of webbing.
For leather, I use the speedo-stitch awl.
dLj
Mar 23, 2017
5,276
For sewing heavy fabrics and/or multiple layers, having a walking foot machine is really helpful.
A lot of heavy duty machines often have an add-in that gives it a walking foot but I have no direct experience with those. That Singer 4411 has such an add-on - might be interesting to know how they may work...
dj
Aug 17, 2013
1,347
Pearson P30 202 Ottawa
For a good machine, Omega has a lsz-1 clone (even sailrite is a clone btw) same fonctions, zig-zag, walking foot, large stitch, just a different colour, I have use done when I started my side business (canvas work) I fixed many sails, made Bimini’s dodgers…. Many things, works like a champ. Very decent price compared to sailrite, still use it for sails, but got a dedicated industrial walking foot for the rest. Might be a good solution for you.
There are many good sewing machines out there, take your time to see what you want in the end, they are not 5$ machines so better to figure what you want in the long run before buying.
Just my 2 cents
Likes: Timm R Oday25
Wila
Nov 7, 2026
3
West Wight Potter 19 Round Lake, SK
For what it's worth decades ago had an oil bath singer 251-12 high speed straight stitch. Bought it with a new table and new 3/4 hp motor at a very reasonable price(vancouver sewing machine, no idea if still around). Quick search shows under 200 bucks on ebay, no table or motor. They're pretty much ancient now, but wow that was a great sewing machine. Very easy to use, only part to learn is a light foot on the peddle.
edit: see there's one on ebay with table and motor 350 obo.
capta
Jun 4, 2009
5,123
I've never had the problem you are describing, but with the adhesives available today, I should imagine a properly cut piece of leather could just be glued into place?
