Seeking sewing advice
Sep 24, 2018
4,821
Catalina 30 MKIII Chicago
I'm in the process of repairing my winter cover. The slits/cutouts for the stays have chafed over the years. I'm tryng to installing leather bias binding (aka trim) around the curved area of the cutout without much luck. The manufacturer put canvas binding on to finish the edge. I was thinking that it might be easier and faster to sandwich the fabric between two layers of leather. I could even have the leather go past the binding for added durability.
Would this be a good strategy? Does the leather need any kind of treatment to withstand the elements?
Sep 24, 2018
4,821
Question - is that referencing real leather or the modern synthetic leather?
dj
The canvas shop that repaired my bimini stated that faux leather lasts about seven years and real leather lasts the life of the canvas when treated nicely in the Great Lakes
Likes: Timm R Oday25
Mar 26, 2011
4,065
Corsair F-24 MK I Deale, MD
A
I'm in the process of repairing my winter cover. The slits/cutouts for the stays have chafed over the years. I'm trying to installing leather bias binding (aka trim) around the curved area of the cutout without much luck. The manufacturer put canvas binding on to finish the edge. I was thinking that it might be easier and faster to sandwich the fabric between two layers of leather. I could even have the leather go past the binding for added durability.
  • Use fabric edging again.
  • After installation, soak it with Yale Maxijacket. I know this is hard to believe, but it will extend the wear of Sunbrella and similar fabrics by 5-10 times.
  • If you can't find Maxijacket, there are alternatives ... but Maxijacket is better. Liquid Chafe Protection - Practical Sailor
I did this on several projects as much as 20 years ago. The stuff is amazing in this type of applications. Use the clear.
Likes: capta
Sep 24, 2018
4,821
Why would this be the best way to go? Some spots need a canvas patch anyways. Leather edging is not within my skill set at the moment. I Should be able to do fabric without an issue. I am in a race against the weather.
Mar 26, 2011
4,065
a. The fabric lasted a good while. With a Maxijacket coating, it will last 4 times longer. (I would coat the fabric in the area as well) At that rate, the repair I described will outlast the cover.
b. Leather edging is difficult. Less flexible. You need soft leather, which will not wear as well as you might hope.
A good way to patch the fabric in high stress, high-wear areas, BTW, is to bond the fabric layers together, creating a material almost like a belted tire sidewall. Much stronger, tougher, and more wear-resistant than sewn patch layers. I've been using this method for ~ 20 years. Sailmakers don't like this method because the curing time keeps them from getting to the next job. I don't know if this is applciable to your problem; pushing a needle through the laminate would be tough going, although in truth, you would not need the edging. Just laminate about 4 layers of Sunbrella under the current outside (leave excess hanging in, like fiberglass work), trim the edge, and call it good. No leather needed (see the bottom image--tough as leather).
A hot knife is also handy.
Consider how much better this snap is supported by several layers bonded together than by sewn layers. This was 8 years ago (window cover). The snap is still good.
Additionally, if repairing old fabric, the forces are more evenly spread than through needle holes.
Non-conventional. But think. Would you sew fiberglass or laminate it? Are tires sewn or laminated? Are film carbon/kevlar sails sewn or glued?
Sep 24, 2018
4,821
The one semi successful leather edge I did no longer laid flat. It's not an issue but it was a bear to get it there and I did it in three pieces to accommodate the curve. I tried overlapping them but that's a lot of material to go through. The vintage sewing machine did it once but said not again.
The Point taken regarding laminating. Any recommendations for a glue?
Mar 26, 2011
4,065
I have used 3M4200 and Locktite PL S40 (Home Depot). Any polyurethane sealant like those would work. NOT silicone.
Interestingly, used Sunrella works better. If new, scrub/wash it with something hard to remove the water-repellent treatment. It will bond better.
And a cheap hot knife from Amazon. WELL worth the price. They cut a lot more than fabric. Carpet. Bungees. Thin plastics. I keep mine in a holster (so I can hang it up hot) on the shop pegboard. Something like this:
Hot Knife
Jun 1, 2004
8,361
Hot Knife
Amen to that. You'll find so many uses for the hot knife you'll wonder how you got along without it. Cutting polyester cordage (rope) with it was a game changer for me.
Aug 17, 2013
1,347
Pearson P30 202 Ottawa
Leather (if the right kind) is stiff at first, but it will flatten out in a relatively short time, best way is to open the slit as if it were a straight line, bind it and fold back, to help the leather take the fold, hammer it down in the shape you want
Sep 24, 2018
4,821
Hot Knife
I have a half dozen or so old soldering irons laying around. Would that suffice?
When doing this as a binding, the bottom layer of leather would slip to the side as I tried to sew it. A hammer to form a crease would be a big help
It's real leather; however if I was to choose again it would be synthetic material of some sort.
What's the advantage of synthetic over real?
Aug 17, 2013
1,347
Who told you, that it had to be done in one seam?
you can sew one side, then fold it over and finish the job, no slipping
Aug 17, 2013
1,347
Let’s not forget that not every type of leather is the right one, look for a very dense suede, chrome tanned is the best as it will weather very well
Mar 26, 2011
4,065
You can make a cutting blade for the ~ 100W irons by bending a coat hanger, hammering the central arc flat, and shaping with a file. You can also buy just the blade. I did this for years, and it was OK, but the commercial hot knife is much better. Faster heating, better control, better ergonomics.
I'd get a palm and hand-sew it. A hand awl may be useful for starting the holes. (Better than a stitching awl- I have several and I have not used them, for the most part, in 20 years).
Personally, I would go the laminated patch route. Much stronger.
Apr 22, 2011
980
You could get some dyneema chafe protection tubes instead of canvas binding. Slit the tubes open and sew it to the round cutout edges.
Likes: thinwater
Jan 7, 2011
6,018
Oday 322 East Chicago, IN
How about one of these…
Speedy Stitcher 1125 SEW200-BRK Sewing Awl, One Size | Speedy Stitcher Hand Sewing Awl + Thread for Heavy Fabric Repairs Amazon.com
I keep 1 on the boat and 1 at home in the workshop.
I wouldn’t want to stitch a long seam with it, but for punching holes in leather, webbing, etc. it works pretty good.
Before I bought a sewing machine, I used a speedy stitcher to reset my sail cover…not pretty, but functional.
