a. The fabric lasted a good while. With a Maxijacket coating, it will last 4 times longer. (I would coat the fabric in the area as well) At that rate, the repair I described will outlast the cover.
b. Leather edging is difficult. Less flexible. You need soft leather, which will not wear as well as you might hope.
A good way to patch the fabric in high stress, high-wear areas, BTW, is to bond the fabric layers together, creating a material almost like a belted tire sidewall. Much stronger, tougher, and more wear-resistant than sewn patch layers. I've been using this method for ~ 20 years. Sailmakers don't like this method because the curing time keeps them from getting to the next job. I don't know if this is applciable to your problem; pushing a needle through the laminate would be tough going, although in truth, you would not need the edging. Just laminate about 4 layers of Sunbrella under the current outside (leave excess hanging in, like fiberglass work), trim the edge, and call it good. No leather needed (see the bottom image--tough as leather).
A hot knife is also handy.
Consider how much better this snap is supported by several layers bonded together than by sewn layers. This was 8 years ago (window cover). The snap is still good.
Additionally, if repairing old fabric, the forces are more evenly spread than through needle holes.
Non-conventional. But think. Would you sew fiberglass or laminate it? Are tires sewn or laminated? Are film carbon/kevlar sails sewn or glued?
