H49 Bow Thruster
Apr 6, 2004
70
Hunter 49 Downers Grove, IL
Okay, so kind of embarrassed that I don't know this info, but I haven't really had a need to know, until now. We have the 2007 H49, with what I assume was a factory installed MaxPower bow thruster. I don't have a separate battery for it, and have never seen a separate breaker for it in any panel, like I have for the windlass and cabin top winch. End of last season, the helm control died for it. I replaced with a new control (having to realign the wiring to match colors, as MaxPower apparently has changed that in the last 19 years).
Control now powers up, and I swear when I first tried it, the motor ran for a second, but then stopped. I still have power at the controls, and can hear the solenoids get thrown when the buttons are pushed. Props spin freely by hand. Both house and starter banks have over 13v. I was hoping to track down what I assume is a high amp fuse, so I can test that, but have no idea where it is. I have tracked wiring from the bow berth, into the floor of the forward cabin. Harder to trace thru the floor of the main cabin, but there's a 200A fuse in the starter battery compartment that looks like a strong possibility? It tests fine.
I have reached out to MaxPower and they have a few questions for me. My google search indicates either a blown fuse, possibly burnt relay contacts, or a bad control box. ANyone here had similar issues with their MaxPower thruster?
Apr 6, 2004
70
Was going to delete this, as I effectively found the answer with a bit more digging on board. But figured that I'd share in case anyone else might need the info.
On our boat, that fuse (which is indeed blown on our boat) is in the house battery area, under the salon table. On the starboard side wall of the compartment, there are 3 big 300A Class T fuses, and the bottom one on our boat is for the bow thruster. I have a replacement on hold for me, so as soon as I can get a ride to pick it up and get back to confirm that solves the issue, I'll edit/update this reply with final outcome.
Thanks!
Likes: kloudie1
7,749
Alden 50 Sarasota, Florida
A voltmeter and 5 minutes should tell you where the problem is. Check voltage at the thruster motor when you energize the solenoid. If you have 13v there, “voila”. if not, trace back to where you have power
Apr 6, 2004
70
Don -
That's effectively what I did. I was obviously getting some power there, the solenoids were tripping when the buttons are pushed. And I was not apparently getting power on the mains, but I wasn't sure if that was to to the control box or the control panel or a bad fuse. Which is why I was looking for some insight on where the fuse was located. Took me a couple of passes trying to trace the run, but was able to get the right floorboards lifted and a camera into the right nooks and crannies to trace the wire. And low and behold, the fuse was blown. Hoping to grab an Uber soon to get it, if this weather will break.
T J
Apr 6, 2004
70
Glad to hear you found something. I assume you're still curious as to why a fuse may have blown and will find out before you...:yikes: Avoid bloo-ies. :) Good luck. 'Cuz 300A isn't anything to sneeze at. You might also want to check the fusing against the wire size from your house bank to the thruster motor. Check the BlueSea wire & fusing tables.
Stu -
Absolutely curious, but not sure the best way to test/determine. The thruster, and it's wiring, have been in place since the boat was built. There are two differences that I can think of - I upgraded my batteries to LiFePo last year, and when I went to test the control install before launch this year, the boat was out of the water. Thrusters worked fine with the LiFePo last year, but wondering if with zero load on the props (out of the water) that the batteries gave the motor too much too fast. We're in the water now, so the my plan is to put the new fuse in and give it a test, while trying to measure the draw. Not sure if I'll be able to capture peak draw, but will try. Worst case is that I blow another fuse (i bought a replacement AND a spare). If that happens, i may have to investigate giving the thruster it's out lead acid battery? Fortunately, the vast majority of our time now is anchored off of islands and not going in and out of slips, so thruster is not critical - until it is!!
Thanks for the thought and feedback.
T J
The fuse blew because too many amps were pulled through the fuse. That can happen with the resistance in the circuit is increased or if there is a short. It may be that without a load on the thruster motor it acted like a short, or it may have damaged the thruster motor. Another real possibility is corroded, fouled or loose connections on the cables.
