Docking and stopping with a spring line
Sep 24, 2018
4,809
Catalina 30 MKIII Chicago
The most successful method of docking I've found is to toss a spring line over the dock cleat at a slow speed. I then hop out of the boat and walk to the bow. The line will go taught and the boat will bounce backwards and the bow will then become within reach from the dock (my hull has a big curve to it). I've tried slowing the boat down to a stop but either the bow or stern will usually start to drift, even though I'm docking to port.
The spring line is attached to a T track which is fastened to the dock with 1/4" bolts. I'm a big concerned about the shock of this docking method. I can add backing plates but I'm thinking a line with some stretch would be the best move. Any recommendations?
Apex
Jun 19, 2013
1,228
C&C 30 Elk Rapids
...not to jump off the boat? At your home dock I leave docklines attached to the dock. pick it up off the dock or piling with a pole from your bow, that way if anything goes awry, at least your still with the vessel.
3strand has good stretch.
Likes: degas
I utilize a similar version of the mid-spring line technique. It is called a Stern Bridle Duncan on YouTube or Venmo. I find it a bit safer as it does not involve jumping off the boat, yanking on the lines, or lack of control in adverse conditions. There is no urgency. The bow is controlled from the helm. You can engage crew or accomplish the task solo.
degas
Aug 14, 2023
82
Tanzer 29 Lake Ontario
Isn't a variant of that called the "marriage saver"?
I've been trying out a similar technique: going bow first, put a spring line from the port stern cleat to a dock cleat that's about midship, then put the engine in reverse at idle. As the hull stops and snuggles up to the dock, I can then tie off the bow and the other dock lines with no rush.
Well, that's the goal. Still working on perfecting it.
What matters more to me is convincing the marina to give me a slip that matches wind and current and reverse prop walk. The ideal for me is a bow first, port side, headwind slip.
I'm just thankful as a Great Lakes sailor that I don't have to do Med-style stern-only docking.
May 1, 2011
5,593
Pearson 37 Lusby MD
My spring lines are the first lines I pick up when I enter the slip. I use traditional docklines. Have never had a problem with shock on the aft spring line cleat on the dock. The forward spring is wrapped around the outer piling in the slip.
Likes: degas
