How to prevent mildew during winter
Feb 16, 2021
545
Hunter Legend 35.5 Bellingham
I leave town for winter, and the past few years have fought mildew in the v berth and aft cabin. I leave a thermostat controlled heater on, leave all my lockers open and remove all bedding, leaving cushions loosely positioned for circulation. I have left the v berth hatch and gate port lights cracked for circulation as well.
I’m thinking of adding a dehumidifier to the mix and closing the hatch and port light. I’m also thinking of adding a fan to both the aft cabin and v berth. As I’m gone for several months in the winter, I’m unable to regularly check on my boat. My concerns are fire risk of running these nonstop, unit failure, as well as excessive power draw/cost.
Any thoughts/input on best practices in this regard?
I’ve used a dehumidifier for a couple of seasons now. It had worked well. I set up a drain hose to the boat exterior. Last year when there was a deep freeze, ice formed in the hose and the unit shut down. The dehumidifier works well until the temperature drops to freezing. Then it is of no value. With the temperature dropping I’m planning to shut down the unit til spring.
I'm surprised that leaving a heater or dehumidifier running unattended would be tolerated by a marina (OP didn't say his boat is in a marina or boatyard). Maybe practices are different in the PNW?
Jan 4, 2006
7,867
I'm in you're backyard and vice versa and not a trace of high humidity or mildew up here. No sources of water vapour either (that I've found) including leaving the toilet seat down. Bilge is bone dry with nothing but dust and cobwebs down there. I think bilges are a big source if wet.
Ventilation, ventilation. ventilation, ventilation.
Likes: FastOlson
Apr 8, 2010
2,258
Ventilation is one key thing. I leave the cabintop vents open and hatches on "vent" position. I have added vents to all settee fronts, and every winter we take all the cushions home until spring. No smells or mildew.
About every 5th season we do wipe down the interior hull surfaces with some soap/bleach and damp rags, also. Well, the parts we can reach fairly easily...
With a keel-stepped spar, I do have to dry out the bilge once a week in winter storm season, also.
Ventilation and heat. shemandr's caution is well placed, however I never left the heater on more than halfway unless I was there. A 600 to 900 watt load on a 1500 watt circuit should not be in issue for continuous load, assuming you have confirmed that your boat wiring is correct and done properly. Without heat it rains inside: cold 32F deck with snow over 47F boat in water. The fan is a good idea if you have areas that get issues recurringly. Don't forget to clean up before winter.
Mar 26, 2011
4,053
Corsair F-24 MK I Deale, MD
Local knowledge helps. There are many helpful people here, but each has a different experience.
  • Climate. Lakes vs. PNF vs. Florida.
  • Boat. Wet bilge vs. dry bilge, for example (yeah, I've heard the lectures--it is not always possible). Different material, hull liners, etc.
  • Different standards for mildew.
  • Perhaps only one experience. They have done it one way but have not tried other ways.
  • Different marina policies.
  • Do they spend time on the boat in the winter? (this adds humidity)
Dehumidifiers. You do NOT want a compressor-based unit. They will ice in the winter (below about 55F) and are more prone to overheating., Moreover, they are just more than you need. Look for a small Peltier effect or regenerating desiccant type. There is no need to remove more than a pint in a day. Low electrical draw and thus, minimal risk.
Locate it in a safe location. I like the stovetop (nothing can burn). The drain should go overboard (sink if high enough, or the cockpit).
In a drier climate, good ventilation is sufficient. Not in the water, in cold climates, where the air and water temperatures can be very different. Condensation can be excessive.
Consider insulating windows and other condensation-prone areas.
I'm not comfortable with heaters. Also, what is important is the differencial between inside and outside, not the temperature, and there must be some air exchange, or you are just creating a hot house (heat ONLY lowers the humidity IF there is air exchange).
My experience on the Chesapeake Bay for 40 years, with fabric liners, is that a small Peltier effect dehumidifier and NO heat is the best combination. Pillows stay fresh. My last boat had dust in the bilge, this one is wet.
Feb 10, 2004
4,254
Hunter 40.5 Warwick, RI
See my post #5 below from a few years ago. I have been using this technique for over 25 years now with pure success. The cost and labor are minimal. No power consumption, no risk of fire. If you normally have a wet bilge, be sure to vacuum our all of the water. Keep the hatches closed so you don't introduce more moisture.
