Is there any place to install a Sierra MP41400 Pressure/Temp Audible Warning Kit on a 5411 international diesel?
Don,Check the Kubota engine equivalent on-line manual. I don’t have a link but should be easy to find. Therein lies your answer.
The simplest ready made solution would be to screw the temp. sensor into an avilable hot AF hose such as this one that goes to the hot water heater :so we do not have a ready-made solution for that engine.
Because all sorts of nasty things can happen when you're not directly measuring the flowing AF temp.Why not a Aqualarm Wet Exhaust Overheat Alarm Kit.
If the AF pump were to give up the ghost, no hot AF would reach the heat exchanger and the wet exhaust would actually cool down. You wouldn't have a high temp. alarm from the Wet Exhaust Overheat Alarm but the internals of the engine would be seriously overheating.
Something which beats an Aqualarm Wet Exhaust Overheat Alarm Kit is the Aqualarm Water Flow Switch which informs you immediately when sea water stops flowing :
Oh stop it, you're making me blush now.Impressive, R Johnston.
I don't understand what you meant that I meant with the word "ghost". Didn't see the word "ghost" anywhere in my post #6 but then again, I've often been told I'm blind in one eye and can't see out of the other. If you could explain ?I did not understand what you meant by ghost.
Hopefully you're on to something.I have this female 3/8” mpt threaded port before the thermostat on the housing that I was thinking a that’s about using for the cooling water sensor.
I know the fitting you mean. Oil ?My Yanmar had one NPT and one BSP thread that I used for the sensors. That was its own little puzzle.
I think it was for the oil pressure. With enough tape or dope NPT to BSP will work. Or so Im told.I know the fitting you mean. Oil ?
I had a 1/8" NPT tap in my toolbox and threaded the BSP fitting to 1/8" NPT and called it a day. Nice snug fit.
Oh, I was wondering about 4511 runs 135°F and 150°F and the sensor is set at 200° F I am in fresh water.Maybe off topic here but I think some of the 5411's are raw water cooled. If so, does that mean it would need a different temperature sensor that would signal the audible alarm more in line with the lower temperature a salt water cooled engine would run at?
