My sailcover seems to be letting water through as we find water coming out the bottom when the boom is moved. Now it's making me wonder if it's actually protecting my sail from the sun. What are some indicators that it may be due for replacement?
I just use 303 fabric guard to restore the waterproofness.
I have actually tested the UV blocking properties of new and very old Sunbrella. No measurable difference. For this reason, it is accepted practice to re-stitch genoa covers. The important UV damage with covers is always from light leaks around the mast and at the end of the boom. Damage to the clew or bolt rope.My sailcover seems to be letting water through as we find water coming out the bottom when the boom is moved. Now it's making me wonder if it's actually protecting my sail from the sun. What are some indicators that it may be due for replacement?
Thank you for a straightforward answer. What about light that bounces off the deck and through the semi open bottom of the cover?I have actually tested the UV blocking properties of new and very old Sunbrella. No measurable difference. For this reason, it is accepted practice to re-stitch genoa covers. The important UV damage with covers is always from light leaks around the mast and at the end of the boom. Damage to the clew or bolt rope.
As others have said, there are other reasons covers do not last forever.
The head webbing of furling sails is notoriously vulnerable for the same reason. Painting the exposed bits is smart.
I put a patch over some lazy jack holes and zippers this winter. It's possible that this is where water is coming in. I also wouldnt be surprised if the old fabric was leaking water. I have a 3M version of 303 that I've been meaning to useAre you sure the water is coming through the fabric? Zippers and open ends are the usual suspects there. If you are sure it is weeping through the fabric, then the common waterproofers work well.
I always specify our sailcovers to be fully lined with dacron. The main reason is to help with chafe, but it also has the added benefit of better UV protection and better waterproofing.
Mark
Any light leak could be a problem, I suppose, but in practice I think reflections are not enough to matter, unless the gaps are huge. The bottom should be closed by twist fasteners, buckles, or somthing.Thank you for a straightforward answer. What about light that bounces off the deck and through the semi open bottom of the cover?
My sailcover came with the boat. I have some of the 3M water repellent on hand. I can tell that the fabric is older just by the way it feels. Like a sail, it's a bit stiff when new. This material is very flexibleWhen you have something built with Sunbrella, you have the option to use regular threads or more expensive threads that hold up to the environment better and longer. Pick the latter. 303 Fabric Guard is recommended by Bainbridge for waterproofing.
