Solar panels
TheTY
Jun 21, 2016
19
Hunter 380 Collingwood Ontario
I’m looking for suggestions on installing a rack for solar panels on my 2000 Hunter 380 that has a crome radar arch. I have 2 semi flexible solar panels (that I might have to replace) that were attached to the Bimini top via screws going through the canvas, but I’m getting new canvas and don’t want to put holes in it.
Attach some metal or magnets to the panels and then a rare earth magnet on the inside of the canvas. No holes. The panels stay put.
Likes: Hello Below
Sep 24, 2018
4,823
Catalina 30 MKIII Chicago
You can attach the solar using one of the following: a clear pocket in the canvas since they are flexible, a frame that attaches to your bimini frame or attach them to your arch
Flexible panels have a short life when installed on a flexible surface. The small wires inside the panel will break when subjected to repeated flexing. Flexible panels will work on a curved surface if the surface is hard, like the top of a hard dodger or cabin top.
A rigid panel on the arch will be your best option.
Photos of your arch will allow us to make suggestions on how to mount the panels.
TheTY
Jun 21, 2016
19
Thank you for replying. I’ve had the panels for about 6 years and there still an output of 13.5. I’ve thought of attaching a frame to the davits but they are pretty low and I can see hitting my head a time or two. And, I would probably need to get solid panels.
TheTY
Jun 21, 2016
19
Thanks for everyone’s response. I’m going to the boat show in Toronto in January so I might get some ideas there.
Is this the voltage after the controller? Voltage is important, more important is the current being produced at that voltage. If the panels are meeting your electrical needs, then there is no reason to change them.
TheTY
Jun 21, 2016
19
John, thanks for idea, I would have never thought about it. I am going to go that route with the magnets. I’m doing some research now on them and will have a plan shortly. With 6 powerful magnets on each panel, they shouldn’t go anywhere. Thanks again.
Ty
KEEP IN MIND... Do not get the magnets near your compass or your AutoPilot compass. :biggrin:
