Jib Seldon Furlex and Jib Halyard Swivel Issues
Jun 2, 2022
17
Hunter Hunter 39 Hartge Yacht Harbor
Hi,
I have 2011 Hunter 39 with occasional problems when furling the jib. I have had to partially dismantle the Seldon Furlex at the jib base to untangle the line. A new line improved the issue but it still occasionally binds. Likewise with the jib halyard swivel, solved for a while by spraying the bearings with silicone.
I am considering replacing both items, but would like to get upgraded or better ones. I would be very grateful for any recommendations.
John D
I switched out a Pro Furl for a Harken MKIV Unit 1. My boat is a 35 ft CAL Masthead sloop. I have been ecstatic about this upgrade.
Harken suggests this information on their website.
Published ranges (standard package length to max with extra foils):
UnitTypical LOA1x19 wireClevis pinStandard stay / max
022–30 ft5/32–7/32 in (4–6 mm); rod −4, −65/16–7/16 in38 ft 7 in / 45 ft 7 in
128–36 ft1/4–5/16 in (6–8 mm); rod −8 to −121/2–5/8 in45 ft 11 in / 52 ft 11 in
235–46 ft5/16–3/8 in (8–10 mm); rod −12 to −225/8–3/4 in60 ft 4 in / 67 ft 4 in
345–60 ft7/16–1/2 in (11–12 mm); rod −22, −303/4–7/8 in74 ft 8 in / 81 ft 8 in
Good luck.
Likes: JamesG161
Apr 11, 2010
996
Hunter 38 Whitehall MI
I switched out my ProFurl on our 2008 Hunter 38 with a Harken Ocean Series 2. What a difference. The 110% job was near the high end of the capacity for the ProFurl and was often a challenge to roll. What finally made it necessary was that the foil sections had begun to misalign and the sail would bind and would not go up smoothly in the spring and the last fall, it bound and nearly couldn’t get it down.
With the Harken we are at the low end of its capacity and it rolls with much less effort. Chose the cruising foil rather than racing one. Just did not need two sail tracks as we only have one head sail and we really aren’t into racing.
Was not cheap upgrade but am very happy with it.
JRacer
Aug 9, 2011
1,409
Have you talked to Selden in SC about the problem? I have a Selden 200 on my First 310 and have not had any issues. Is the angle the line enters the furler at the proper angle? Same question about the angle of the halyard. How old is the furler? Just some thoughts.
One of the causes of jams in the furling drum is letting the jib unfurl too quickly which leads to overrides and loose wraps. Then when furling the line binds up and over rides form. The solution is to maintain some tension on the furling line when deploying the jib and to maintain some tension on a jib sheet when furling. This will help the line to wrap neatly in the drum.
Also check the lead of the furling line from the first block to the drum, it should be a right angle.
Jun 2, 2022
17
jssailem and quadrille38: I appreciate your recommendations for the Harken units. I will most likely get the Ocean Series 2. My Hunter is at Herrington Harbour South on the Chesapeake. I will enlist the aid of a good rigger guy with installation.
Jracer, Angles of the line and halyard are correct. The Seldon is original (2011)
ciochner: Angle from the drum to the drum is 90 degrees. I maintain mild tensions on the furling line when deploying the jib, and on a jib sheet when furling. Age of the furling is most likely a factor.
I appreciate all of your prompt responses and recommendations.
John D.
Mine is the not the ocean version
Likes: JamesG161
Apr 11, 2010
996
John D.
I think you will be happy with that choice. Your boat is almost identical to our 2008 38. The Selden is a good product but frankly Hunter should have chosen then next larger size when they built the boat.
Our yard worked with an excellent rigger on furler recommendation.
One thing to be aware of - our yard manager thought he could replace the system with the mast up. When he got to the top of the mast he realizes that the attachment of the head stay to the mast was such that it could not be done mast up. That was OK though as it gave me a chance to inspect the rigging and sheaves, install a spinnaker halyard (boat never had one), install a new topping lift, and check over other things.
25
- - Chicago
Hi,
Thanks, John D. View attachment 239826
Have you tried experimenting with different job halyard tension? I have found on multiple boats and furlers being over or under tensioned causes these exact problems. Whenever my 94 37.5 headsail is hard to fuel I loosen the halyard and it suddenly works fine.
Jun 2, 2022
17
NoReverse,
Thanks for the suggestion. I have tried loosening the jib halyard with no effect.
Hunter 34 Herrington South, MD
we had furling issues on our H34 but strangely, 2 of the owners experienced problems and the other two never did. I think that the rate of unfurling make be the cause of many problems. A fast unfurl would seem to impact the coiling of the line leading to cross over of the line in on the furling wheel(?). Try unfurling into the wind in a smooth slow motion.
