Start battery is not charged by charger on 1997 Hunter P42; is there a way to fix that.?
Sep 14, 2004
208
Hunter 42 Deltaville VA
I have a 1997 Passage 42. The Freedom 3000 charger/inverter does not charge the start battery. The alternator does charge it. I believe the CD player/radio (channels and equalizer settings) and the bilge pump are maintained by the start battery. This wears down the battery when left idle for a while and can only be charged up by running the engine or using jumper cables. It also kills the start battery much faster than house batteries. Starter needs replacing after about 4 years of this abuse. House batteries last around 7.
Has any P42 owner solved this issue? How? Thanks.
7,725
Alden 50 Sarasota, Florida
Not knowing the charging circuit makes this a guessing game. You need to map the system wiring and voltage readings. It’s also crucial to know if/how and where the two battery banks are interconnected.
Given the boat is 25+ years old, it’s likely some PO altered the original charge circuit and components. Step one is finding out how everything interconnects.
Don's right, of course. In addition, I would add my experience, even though I don't have a P42. I do have a Freedom 1500, pretty much the same wiring to the house bank for this I/C. But what I did was to run the alternator output (AO) to the house bank and to ADD a Yandina combiner to charge the start bank. An echo charger would work just as well. If you don't want to reroute your AO to your house bank, you can use the Yandina but not the echo charger because the combiner will close the relay on voltage whereas the echo charger is a one way device, IIRC. Good luck.
PS m- Do you have a 1-2-B switch? If so B would charge both banks.
6,060
Our 91 P42 has a power panel on the engine bay bulkhead that looks like this:
Sorry for the blurry picture.
Make sure both switches look like ours. Then come back for further instructions. We've never had a starter charging problem. Also, regardless of the house bank state, it should have no affect on the starter battery state.
P.S. The switches between the two Perkos is for the Genset.
BrianQ
Jan 10, 2024
52
Hunter Legend 37.5 Havelock
A friend's Passage 420 is the same way. If you dock the boat at a marina a simple solution is to add a small battery charger for the start battery. Alternatively, you could use a DC-DC charger to charge the start battery from the house bank.
You could also utilize an ACR (Automatic Charging Relay). Charge power to your House bank. When House bank full the ACR kicks the power to charge your starter bank automatically. Easy Peasy.
Dec 25, 2000
6,060
It seems we will wait for a follow-up from the OP. Our original configuration has worked great since we took possession in 2002. Never a charging or draw problem, unless here, the PO altered the system layout for some unknown reason. Although a complex electrical system with the Genset, Hunter did a class job on the original build layout. Other than making a few additions, I left the original intact, which means the starter battery is used only to start each engine, and that whether connected to shore power, Genset or alternator, all batteries get charged at the same rate, but as I mentioned earlier, draw from the house does not affect the starter battery, and vice versa..
Jul 25, 2004
363
Hunter 42 currently in New Zealand
Hi Terry! I hope all is well with you these days. Long ago I installed a West Marine Battery Combiner in our 1991 Passage 42 to address this issue. It was a relatively inexpensive (50-75 dollar) unit. Our AC battery charger is connected to it, as are our DC alternators. When any one of those charging sources are active, the batteries are all combined to receive the charge. When all charging sources are unpowered, and the battery voltage drops to something like 12.8 volts, the starter battery and the house bank are automatically disconnected
and the starter battery is protected from discharging any further. It’s worked well for us for many years.
Cheers,
Paul
6,060
PAUL! Good morning. My goodness, so nice to hear from you down under. Maybe the OP will soon reply in order to learn more about his issues. Hard to second guess from my armchair. Do you have any pictures to share? Sabina holding up okay? And you? Any plans to come back?
