Quick and easy holding tank pump out device.
Nov 24, 2014
212
Catalina 310 Staten Island
I know this topic has come up before, but sometimes is worth repeating. As the popularity of boating has gone down, so has the availability of pumpout options. Marinas have closed or shut down their pumpout stations, and the boats that offer this service are few and far between. Nobody likes dumping waste overboard and it is illegal unless 3 more more miles offshore, but occasionally you have no other choice. The best option is a portable pump that attaches to a cordless drill, available at many hardware stores or online. I have had good luck with Harbor Freight's version. I do make it a point to go offshore to do this task. I recommend flushing it out with fresh water then spraying dry lubricant after use. The combination of salt water, deodorizing chemicals and human waste will kill it after one season, otherwise
4,792
Catalina 30 MKIII Chicago
I had a boat once that had a macerator, who's outlet was connected to a port on deck. The previous owner described the usage of it with a short piece of hose that attached on deck. This system was nick named "the poop shooter" and was our first line of defense if we came across pirates on the Great Lakes.
Likes: Ward H
Nov 24, 2014
212
Let's just hope that some stool pigeon doesn't rat us both out for illegal discharge of waste
Apr 10, 2010
156
Catalina 310 166 Dartmouth, Nova Scotia
I also have a 310 2002 vintage and have as standard equipment a macerator pump fitted to holding tank. At our Dartmouth marina we have an operating pump out station available to all members. However I am puzzled why you would need a drill operated pump for your tank, was a macerator pump not fitted originally? Or am I misunderstanding something?
Likes: Windpilot
Nov 24, 2014
212
It no longer works.
JBP-PA
Apr 29, 2022
831
Jeanneau Tonic 23 Erie, PA
I have resorted to 5 gallon buckets. I cut a hole in the lid for the hose to reduce spashing. A few trips did the job.
Please post a link to the pump you liked.
Aug 18, 2018
168
Hunter 410 MDR
It no longer works.
[/QUOTE]
Fix it, there's a screw on the end of the macerater you can turn to un stuck it, try 1st. 2nd take it off and apart to see if the impeller is good, if its completly dead like in motor dead replace it. Much simpler, cleaner and the way its engineered to work.
