Bombardier 4.8 missing forestay (I think)
Aug 22, 2026
3
Bombardier 4.8 4.8 Yellowknife
Hi everybody,
I just bought a used Bombardier 4.8, that seems like it is still in good condition. I am fairly novice as both a sailor and rigger, so I managed to track down a 2 page PDF manual on-line, but it is a bit short on pictures and details. From what I can tell I am missing a forestay. The guy who sold it to me insists that all he ever had was the jib furler, and he didn't had a separate forestay. Is there anybody that can confirm that I should have a forestay? I presume it attaches at the same point as the shrouds? I figure if I can measure up the distance I should be able to get one made.
He also said he sailed it without a separate forestay - any thoughts on whether that is a good or bad idea?
Thanks
Darcy
Some furlers incorporated the headstay into the furler. I think CDI was one of the companies that did this. If you could identify the furler's make or provide photos of it, we'll be better able to advise you.
Likes: LLoyd B
For my Bandit 15 the wire in the luff of the jib was the forestay. There was a furler - I don't remember the brand.
Likes: PaulK
What is the Furler you have? The detail of the furler will tell you the answer.
Do you want to abandon the furler and replace it with a hanked-on foresail?
Aug 22, 2026
3
Thanks everybody for your advice - looking more closely I think the forestay is incorporated into the Jib Furler - at the boat there isn't really an extra place to attach the forestay, and there is a metal line in the furler. The only thing that is a bit weird is that means that it is the jib haylard that raises the forestay instead of it being directly connected to the mast. See photos
3
Although, I did track down a manual that indicated there was a forestay, but maybe they changed the design, and the manual I have is for a different version.
That is a continuous line furler which is a different style than many of us are used to. The forestay is integrated with the sail. There is probably a wire luff in the sail which serves as the forestay.
