Hunter 39 Outhaul Line Routing
Jun 2, 2022
17
Hunter Hunter 39 Hartge Yacht Harbor
Jason Currie from Quantum Sails, Annapolis, came to my 2011 Hunter 39 to take measurements for a new mainsail. He said the top outhaul line should be connected via a block to the lower part of the line (See two photos for current and recommended configuration). I purchased the boat in its current configuration. Can anyone provide a description/part number of the necessary block? Thanks, John D.
MFD
Jun 23, 2016
306
Hunter 41DS Pacific NW USA
I have a Hunter41DS.
The car has two attachment points - for the outhaul and a block.
EDIT: Also look at the blocks at the baes of your mast - they will be similar to what you want here. A little shackle and the spring to keep them from flopping around.
Also for Selden rigs - if you look at the base of the mast, you will find a serial number / part number etched in. That will correlate back to the model number and from there, you can find the relevant documentation directly from Selden about how they suggest to do the rigging.
998
Hunter 38 Whitehall MI
Here is a picture of the routing from the Selden manual.
Notice where the plastic donut is located. I’ve seen so many people have it in the wrong place. It goes between the boom and the clew of the sail, not between the sail and the block.
35
Hunter MH37 Mississauga
Any standard 50 or 60 mm block will work with a minimum 2000 lb working load rating. Follow routing shown in the Seldén diagram posted by @quadrille38
Jun 2, 2022
17
MFD, Quadrille 38, and Lemoiney,
I very much appreciate your helpful comments, Seldon diagram, and photo showing the correct car configuration. Interesting that my Seldon manual shows a slightly different configuration than that provided by Quadrille 38. Currently looking for the correct car online. Thanks again, John D.
MFD
Jun 23, 2016
306
Now I have another conversation starter for the local YC or waterfront bar.
Or while visiting strangers when going to/from the boat with the dingy.
Where do you keep your donuts?... :cool:
Oct 29, 2018
35
Both diagrams are essentially identical. One has a turning block built into the mainsail clew while the one you just posted has a clew board and block attached to the clew. How you proceed now depends on the way your mainsail clew is made. The donut is optional but probably a good idea.
MFD, love your post!
