I have a 1992 Hunter 30. As we were anchored out, my wife turned on the DC water switch. The bilge pump started to run. Removed the flooring and the bilge was dry. I played with the float switch, but no luck. After knocking on the bilge, I cut one of the wires to the bilge pump and it stopped.
Thinking the float switch was bad, I purchased a new one and installed it. Reconnected the wires the bilge pump started to run again. I also disconnected the wires to the float switch hoping this would stop the bilge pump, but no luck.
Do I have a manual bilge pump switch that I do not know about? Could not find it in the manual.
I thought the wires to the float were the primary power for the bilge pump, but I am wrong.
Any suggestions would be helpful as it's good to have a working bilge pump.
Thanks
Thanks
