Starboard Bulkhead Replacement
May 11, 2014
48
Catalina 310 Lake Texoma
I about to dig into a starboard bulkhead replacement project on my boat, (Catalina 310, Hull 018).
Does anyone have a photo of the bulkhead after the veneer has been removed or experience with such a project on their boat?
Thanks in advance for sharing what you have.
Sincerely,
Todd L.
Aug 7, 2007
83
- - Oyster Bay, NY
Are we talking about the bulkhead between the sitting area and the forward bed? If so, I have replaced my bulkhead.
The bulkhead did not have a "veneer"; it was plywood with a finished surface.
Attached is the bulkhead removed. It was a bit of a nightmare getting a replacement from Catalina. The first one they sent was not correct. They don't have the specs on our boat. The second picture is what they sent me, and as you can see, it would not fit. So I needed to ship them the bulkhead, and they did duplicate it for me. The final product, with some cutting, did fit.
Not sure what your question is, so if you could fill me in, maybe I can help.
48
Thank you for your reply and the photos; your timing is awesome as I'm emptying the boat now prior to starting this project.
From your photos, your issue appears to be the same as mine, (water from above), and your experience and the photos you've supplied are helpful. I'd be curious about the hull number of your boat to get an idea of how close its requirements/dimensions might be to mine. Is it correct that you ordered your replacement from the Catalina factory rather than Catalina Direct? I'm assuming the part was 3/4" marine plywood with teak veneer on both sides.
Given what you've shared about the piece being a single sheet, I feel like my bulkhead has delamination that will require at least a full replacement of the starboard side of the bulkhead. Do you recall any tricks or insights to dismantling the bulkhead that will help me out? I'm impressed at how clean the edge that was under your door frame is after being dismantled. Is it safe to assume you didn't run into any nasty epoxy or glue joints that you had to deal with?
Finally, can you confirm that you found a steel c-channel backer somewhere under the cedar closet in the VBerth like were used for the lower supports bow and stern of the chainplate?
Thanks again for your reply and assistance on my project.
Todd L.
Aug 7, 2007
83
- - Oyster Bay, NY
My boat is hull 67 2001. So, they should be very close to the same.
Yes, I was dealing with the Catalina Factory and not Catalina Direct.
Back in 2021 I was dealing with Lukas Serafin
Catalina Yachts – Parts Manager
7200 Bryan Dairy Road
Largo, Florida 33777
727-544-6681 x201
Lukas@catalinayachts.com
I believe it was ½” not ¾” but once you pull it you can check that. Yes, it was plywood with a teak veneer on both sides. I also had them stain and finish it. I didn’t feel I had the skill level to match the color.
FYI the cost at the time was about $700.00.
And yes, found a steel c-channel backer somewhere under the cedar closet in the Berth like were used for the lower supports bow and stern of the chainplate
Dismantling was an easy process with no epoxy. Once unbolted and screwed out slipped right out. The only real issue is getting it to fit, which required small trim cuts and filing until I fit.
I also did this on the hard with the mast down.
You also may want to order “welting” which is the flexible leather looking “molding” they use between the bulkhead and the ceiling and sides.
The actual project was easy. But dealing with Catalina was taxing at times.
Good luck with the project.
Sep 24, 2018
4,821
Catalina 30 MKIII Chicago
I did this on another but not on a catalina. It's a pretty straightforward process. Nothing complicated. I think @sailliny's idea to add welting is an excellent one. It's like adding trim to hide the edge of flooring. It'll make a cleaner edge in less time than it would take to sand it smooth
In case you haven't heard, Catalina Yachts is no longer in business. All of the assets were auctioned off in June or July.
Carefully remove the existing bulkhead so you can use it as a template. It will probably be difficult if not impossible to find plywood with the same veneer. Look for a company that specializes in exotic woods like M L Condon they may have an acceptable substitute.
JRacer
Aug 9, 2011
1,409
Advantage Lumber may be another option for exotic woods/veneers.
Oct 10, 2009
1,120
Beneteau 393 Muskegon
I didn't have the option to order a fabricated bulkhead when I removed and replaced both a on a different make/model several years ago, but this sounds like a very similar project. For mine, I sourced a sheet of okoume BS 1088 marine plywood, then I used the old ones as patterns to cut the new ones. This was less expensive and since I was cutting sheets to the exact specs, they fit perfectly on the first try. My guess is Catalina had a pattern for the bulkheads, but that each one may have needed a little trim to fit.
There's an album in my profile if you want to see what the finished wood looks like. Okoume grain is similar to mahogany. I stained it, epoxied the edges.
I was going to recommend ML Condon for a question about plank material on another thread. But I wasn't sure if they were still operating. It's good to see they are. But now their warehouse is in Stormville instead of White Plains.
I've made several trips across the Throgs Neck Bridge with boards strapped to the top of my car.
Aug 7, 2007
83
- - Oyster Bay, NY
If you go with doing it yourself, you may want to contact this company. At the time I was doing my research, they supplied Catalina with the stains they used.
May 11, 2014
48
The project progresses; thanks for all the photos, guidance and suggestions from your experience.
The mast is down and the chainplates are out. The deck and port bulkhead are fine and the starboard one needs replacing, (and our project is "in time" as all the hardware is still in great condition). We've pulled everything out and found the edges of the piece to be replaced very brittle from water damage but firm at the anchor points with the exception of the very top, (it was 1/2" thick). While we're waiting for delivery of our new bulkhead panel, I've built a 1/4" template to use to get the dimensions very close prior to cutting and personalizing the fit for the new panel.
I have my Target Coatings water based varnish, replacement welting and rust proof staples for the edges of the panel.
In separate news I've decided that the screws holding the rub rail bracket need re-bedding and at the end of that effort well replace the vinyl of the rub rail rather than trying to reuse the original. And finally, prior to raising the mast we'll review/repair/replace its wiring and put a new wind vane up, (all work I should have anticipated).
Todd L.
CrispyEdges.jpeg TemplateCropped.jpeg WaitingForNewBH.jpeg StarboardBHcropped.jpeg
Oct 31, 2022
119
Catalina Capri 22, Catalina 42 MKII Huntington
Where did you end up sourcing the panel for the bulkhead? And which varnish did you go with?
May 11, 2014
48
I didn't have any luck finding a source for the panel to the specs needed in my area so I contracted with a local company that supports furniture makers to "make" a panel to the specs I needed.
CatalinaDirect.com has an article to help you determine which finish was used on your boat's production at ...
Interior Finish History
Catalina Direct has pint cans and Taylor Coatings can supply gallon cans.
Likes: Sail22Capri22
Oct 31, 2022
119
Thanks, I’m looking forward to your results. I hope you post some photos of it.
May 11, 2014
48
We're still making good progress without a lot going on that warrants more photos. Work has been focused on the rub rail mount rebed, mast rewire, replacing a bent lifeline stanchion and getting the new bulkhead blank finished with multiple coats of the Taylor Coatings water based varnish.
The three photos attached show the dry fit of the bulkhead blank and the blank after a first coat of varnish. The photo of the port bulkhead shows a bit of water damage around the bolt holes but otherwise nothing of concern. We plan to drill out the slight damage with a 3/4" drill and fill the holes with glued in ply plugs to make sure we get a snug fit on the chainplate bolts when it all goes back together. We customized the glued in plug's size to be sure the chainplate will cover them when it's installed.
May 11, 2014
48
We're getting down to the "little things" that won't mean much to most of you unless you have had some "nits" that you've always wanted to fix but didn't get to.
I won't bore you with the list but a good example is the following:
The bent lifeline stanchion on the starboard has always needed attention, (first photo, goop in place from my PO; maybe longer than 10 years). The rubrail was also badly chewed up just below it.
Addressed! I only have one photo of the PO's fix on the bent lifeline stanchion, but now the replacement lifeline stanchion is rebeded and in. We also rebeded all the rub rail mounting screws, (the source of leaks in the VBerth we believe), prior to putting on a new rubrail! It's so satisfying to see that little bit of Boat Life squeezed out as the screws went it.
I mentioned the custom sized "ply plugs" we fashioned to remedy some water damage where the bolts passed through the port bulkhead in my last post. I've reposted the photo of the before repair bulkhead and today I have photos of the plugs after being glued in but before varnish posted.
May 11, 2014
48
Lots of little projects going on now, (towel hooks for the bulkhead, crib board refinishing and cushion cleaning and conditioning)...
...but the chainplates are polished and installed and we'll raise the mast next week just in time for fall sailing in Texas.
