I know, I know, I know. Jeeze.Looking at those linked articles, it appears that these paints are designed for radiative cooling as well as normal reflecting (blocking) of sunlight. The radiative cooling aspect is what mostly sets them apart from any normal reflective paint (bright white), with increased reflection a minor difference.
So measuring the temperature of their surface isn't the correct way to judge them. This would only, at most, show any difference due to reflection. At worst, it will show increased temperatures due to radiative cooling.
The correct measurement seems to be measuring the inside temperature of something coated with the paint. Maybe paint a fiberglass or metal container with a temp sensor inside?
Mark
If you just finished a couple test panels, tell me you wouldn't throw it on something hot and see what happens.
