Pump fitting sealant
Sep 24, 2018
4,788
Catalina 30 MKIII Chicago
Do these style of fittings require any sealant? It looks like the other end of the nipple gets pressed against the pump outlet to form a seal so sealant would normally not be needed. I found one leaking below the waterline. I'm not terribly confident in it for this application
Mar 6, 2008
1,524
No sealant needed. If it is leaking, replace the O ring inside. It is for the fresh water system so below water line has nothing to do with it.
