Holding tank won’t empty
Aug 3, 2024
4
Hunter 33 Lloyd Harbor
I cannot get my holding tank to empty. Assume it’s the air vent or physically clogged. Love to hear your ideas to clear
Aug 3, 2024
4
No. I didn’t hear air being sucked in while attempting to pump out. Tried two different pump outs but same result
7,724
Alden 50 Sarasota, Florida
Not sure hearing is a definitive method compared with feeling it. If the vent doesn’t vent, you have the reason.
Mar 6, 2008
1,514
Using shore water hose, force water into the holding tank vent. Does it look like water is going in. If not, at the holding tank remove the vent hose then try it.
Also pour water down the pump out hose. Does it go down to the holding tank?
Sep 24, 2018
4,682
Catalina 30 MKIII Chicago
I had the same thing happen once. The hose clamps for the pump out hose on my boat were loose. Does the marina's pump out hose collapse a bit indicating suction or is there no change when you press it against the por ton the boat?
Oct 26, 2010
2,227
Hunter 40.5 Beaufort, SC
Another possibility is that the internal pipe that goes down into the tank is separated or broken. If I recall the design correctly, there is a pipe that goes from the pump out connection on the tank down to near the bottom of the tank. The vent line goes into the top of the tank so when a vacuum is applied or the macerator is run, the suction is taken from the bottom of the tank through that pipe. If the pipe is blocked or if the pipe has separated from the connection the tank will not pump out. On a friend's boat, something got into the tank and "plugged" the pipe and he could not pump out.
Aug 13, 2020
3
Hunter 31 Dahlgren, VA
If you have a Y-valve, check to make sure it’s in the right position. You could also run a plumber’s snake down the pump out line to make sure it’s not clogged. The vent line can be easily disconnected and blown with compressed air.
Alan K
Feb 22, 2004
62
Hunter 380 Norwalk, CT
I had an intermittent situation where I could not pump out my Hunter 380 holding tank. It mystified me for years. I finally cut an access port in the top of the holding tank.
As previously mentioned, the pump out fitting on the top of the tank was extended inside to the bottom of the tank with a piece of flexible hose. The end of that hose was loose in the bottom of the holding tank. It was exactly the right length so that it could get wedged perpendicular to the inside of the holding tank. Attempting to pump out the tank just sucked the end of the hose onto the side of the tank so that nothing could pass.
The problem was solved by cutting an inch off the pumpout hose so that it couldn't reach the side of the tank.
Likes: BigEasy
Oday 30 Stamford CT
The screens in the metal vent fittings for the water tanks and waste tanks clog up with corrosion. You can try using a garden hose to clean the screen or disconnect the hose from the vent fitting and try pumping out your tank again. Good luck!
Sep 24, 2018
4,682
Or as a test, disconnect it from the vent side, if it still wont pump out, disconnect it from the tank side. As a last resort, you can try poking something such as a screwdriver in the tank where the vent hose attaches. If that's clear and you still can't pump out, then you know for sure that it's something in the tank or pump out line
Oday 30 Stamford CT
You can also test that the shore side pump is working by placing the pump hose in a pail of water or stick it in the water next to the boat.
Hunter 34 Alameda CA
I didn't either. All my hose clamps were tight until I tightened them again under the deck pump out fitting. Then it worked fine. Sometimes the rubber creeps and things can get loose.
Jun 21, 2004
3,213
Beneteau 343 Slidell, LA
Consider that dockside pump & hose has air thats causing pump to lose its prime.
Mar 26, 2011
4,009
Corsair F-24 MK I Deale, MD
Another common cause:
Did you take ALL of the loops of hose off the rack before pumping? If not, the water has to rise 2 feet for every loop on the rack, yes, it will syphon once totally full, but it isn't to start, and if there are ANY air leaks, it never will be. Five turns on the rack can be an extra 15 feet of lift, added to the lift from your boat and hose friction, which the pump can't do.
Hose on the rack is bad. Lay it on the dock.
Many of the instructions leave off step 3, which really needs to be step 2. I guess they think it is obvious.
