Request for instructions to wire 1997 Hunter 376 VDO Quartz hour meter to Yanmar 2JH3E
Mar 26, 2015
113
Hunter 376 Marina del Rey
Good day all,
It’s been a very long time since I’ve requested your assistance.
The hour meter on my boat quit working. I hired an electrician to repair/replace the unit. He disconnected 2 wires from the power and ground positions.
He returned, a few days later, with a new hour meter from another manufacturer. He told me he didn’t feel well, and hadn’t for several day. He left, without installing the new meter.
I’ve called to ask him to complete the job. Then I called to inquire about his health. No answers.
So, I have the existing VDO Quartz hour meter, model LR155-20, with disconnect wires at the power end and no idea where to connect them.
ChatGTP offers possibilities, but nothing definite. Can any of you captains provide a picture or diagram of exactly where to connect the positive and negative wires.
In case you couldn’t tell boat electronics, beyond lights, is beyond my skill set.
Thank you.
Kind Regards
Tim Hollar “Diablito”
142
Catalina 310 166 Dartmouth, Nova Scotia
My old yanmar 2gm had the hour meter/tach power from a magnetic sensor on the flywheel housing. I would suggest one vdo lead go to ground (negative) and the other to the hot side of the start switch. That's the side that is energized when the engine is started. Try a temporary hookup to ensure it functions as intended.
:plus: With @east coaster. That is the way I wired mine, after the engine rebuild.
Mar 26, 2015
113
Mar 26, 2015
113
Thank you. I’ll test first, as suggested. Hunter doesn’t have (or share) a schematic of this function.
Cheers!
Apr 10, 2010
142
The hunter forum group is a great source of info and experience. Just go to "forums" on the left side of this page and scroll down. There are many of them so take your pick. With diligence you will find your answer.
