Overheat adventure on 1985 Universal M12
Jul 5, 2011
771
Oday 28 Madison, CT
I have one of the Mr. cool replacement heat exchangers, copper nickel. The good thing about these is that you can service both ends as they have removable caps at each end. Is it theoretically possible to remove the cap at the far end and run the engine and flush the water into a bucket thus cleaning out any debris that way or is that a crazy idea? (I am thinking that if I don’t get consistently good water out the exhaust next time I go out, I would take a hard look at the heat exchanger and the possibility of debris.)
Mar 6, 2008
1,517
Remove the heat exchanger and clean it. I would think it would be a bog mess the way you are describing. Also your engine will ovetheat.
Catalina 34 Casco Bay
Remove both end caps and use a .177 cal ( BB/pellet gun cleaning rod) to rod out the tubes. Check the zinc while you are there.. DO NOT apply teflon tape to the zinc threads if it needs replacement.
Jun 11, 2004
1,933
Oday 31 Redondo Beach
Thank you very much. What’s the no-no on the Teflon tape?
Some think it impedes electrical continuity between the anode and the HX. Others say the threads will cut the tape enough to make electrical contact.
the anode is in place to be sacrificed to stray electric current. It needs a proper ground from its threads to the exchanger. As Richard noted there are differing thoughts..
As you state, “It needs a proper ground from its threads to the exchanger”
The threads provide that electrical link as the exchanger should be connected to the engine, and thus to ground.
Teflon tape is there to reduce the chance of leaking. If there is no leak (and there should not be based on the type of threads used for the zincs and exchanger), then no need for the tape. If there is a leak, check and clean the threads.
Fun Fact: Teflon is used on some electrical wires as electrical insulation. It helps to reduce the smoke should a wire overheat.
dLj
Mar 23, 2017
5,181
Irrespective if there are breaks in the threads, it will always have greater electrical isolation between the anode and the threaded hole. You do not want that in this application. @sailme88 is spot on - do not use Teflon tape.
dj
376
Oday 35 Barrington / Warwick RI
Sorry that I am late to this party.
The thermostat has nothing to do with this.
I have had a similar problem after the first run of my engine (M25) after the launch of my boat. The problem is that you can get a stubborn air bubble in the raw water circuit. It can be stubborn enough that the vanes in the raw water pump cannot develop enough suction to get the pump primed. What you did in opening the pump, LUBRICATING IT (I use dishwashing liquid soap - I coat each vane, then use the bottle to give the pump a squirt), and then closing the pump back up, solved the problem. Hopefully, you are running the "new" style Oberdorfer pump that has an O-ring, rather than the old type that used a gasket.
Also, be careful if you ream out the old H/X. Some of the holes/pipes DO NOT GO ALL THE WAY THROUGH the H/X. If you push it, you will cause a leak in the H/X, and have to find a boiler repair shop (yeah - good luck with that), or buy a new Heat Exchanger.
Also, the 3" x 13" long H/X is ALWAYS an upgrade to the 2" x 16" L heat exchanger. The 3" has removable end caps, and the 2" does not. I once sold someone a perfectly good 2" x 16" heat exchanger to replace the M12 - a 2" x 12"L spec'd for the M12. The guy returned it, and I gave him his money back, because he stated that it wasn't "supported" which it technically wasn't. It was 4 inches longer, and provided extra cooling capacity compared to the 12". The guy felt that the engine would run too cool, which was incorrect. The engine temperature should be controlled by the thermostat.
376
I don't think the raw water is affected by the thermostat. Only the coolant.
FRESH WATER CIRCULATION DIAGRAM
ALL MODELS EXCEPT M-15
Normal Range 165F to 195F
Sorry, I can't get the diagram to print here. Attached is a PDF.
FIGURE 13
1. Sea water enters through sea water inlet,
2. Through sea water valve when open,
3. Through sea water pump into heat exchanger to cool fresh water system,
4. From heat exchanger to sea water overboard through exhaust port.
FRESH WATER
1. Coolant (fresh water with antifreeze) is introduced into the system from the coolant section of
exhaust manifold by removing pressure cap and filling manifold tank to within one inch of
lower rim of fill port.
2. Fresh water engine driven circulating pump moves coolant from heat exchanger through
engine block circulating pump and thermostat back through exhaust manifold into heat exchanger
to be cooled.
The manifold serves as the engine expansion tank to allow for expansion of coolant as it is
heated. You also fill the system at this point. In some cases when hot water heaters are installed
an expansion or surge tank may be required to prevent air from entering the system.
Should your engine overheat, first check coolant level to make sure it is not low which would
cause air locks to develop. If air does enter the system, it may require a couple of fillings to
remove the air pocket. A momentary increase of engine R.P.M. to approximately 2800 to
3000 R.P.M. may aid in moving the air from the system. In some cases it may require doing
this 2 or 3 times. Do this just as you notice the temperature starting to rise above normal.
Here is that pic;
Jul 5, 2011
771
Oday 28 Madison, CT
I have now done a few more things and no joy on getting the issue fixed. She’s running close to 200 and not even a full throttle which is not correct at all of course. I am going to now replace the thermostat. The service manual calls for an adhesive on the cover side of the thermostat flange. Does anyone know what kind of adhesive they would be talking about; something like a permit gasket seal maybe? Also, I am very worried about sharing off the two hex bolts. I know from experience it sometimes applying some heat is a good thing to do when you suspect something is frozen. Also tightening a tiny bit before loosening is another trick. Anyone got any experience with this? To heat it I could simply run the engine up I would think, loosen the two bolts, shut the engine down until it cools and do the change out then but again, any advice would be helpful.
You could also use PBBlaster or Kroil on those beforehand when cool and let sit for a day. If you just 'think" they may be frozen, why not try to see first? Planning always helps, worrying unnecessarily never does.
I've replaced thermostats on my M25 a number of times, never used anything but the proper gasket, no adhesive. A liquid type gasket is NOT an adhesive anyway, it is a sealant. The last thing you want is an adhesive, because it is something you will eventually want to remove.
Likes: eherlihy
dLj
Mar 23, 2017
5,181
If it were my boat, first thing I would do is take a thermocouple and check the accuracy of the gauge that is giving you the 200F signal. It could be the gauge.
Perma gasket is a decent sealant - although I typically don't like sealants there, it depends upon the mating surfaces. If the surfaces are nice and flat and in good condition I'll just put the gasket it. That's on a case by case situation.
To get the bolts out, I would get a six point socket or wrench depending on what you have and then apply torque to see if the bolts move or not. I may work it back and forth depending on what it feels like. If no joy, I might soak it in a penetrant like PB Blaster for a day. Then try the removal process again. Still no joy, I might use a torch to heat the area of the threads but that is very much dependant on access and what things look like. I would not heat up the whole engine as that just gets everything hot and tends to make it more difficult to remove those bolts.
dj
Likes: Stu Jackson
Sep 28, 2025
112
Catalina C 30 MK1 1983 Stockton Lake Missouri
I have a rebuilt universal diesel 5411 in 1983 Catalina C30 mk1.
When my ignition key is off and the engine is running the temperature gauge is off and will show the temperature about 190 to 200 degrees.
I don’t know why I turned the key off that day. Must’ve been a short between the headphones.
There is a small hole in the thermostat housing that allows a small amount of water to flow through the exhaust outlet until the engine reaches 135 and opens the thermostat. Until then, the water flows through and back into the cooling water pump and not out the exhaust system.
I know you said you have an M12 and I don’t really know the difference so I don’t know if this really helps.
When the engine is off (after being warmed up and/or used to where the T is at operating temperature) when the power to the gauges is disconnected the T will stay at its last reading until the ignition switch is turned on, and if the engine is cooled, the T will start at cool/cold. This is NORMAL.
When you turn the ignition switch off when the engine is running, it disrupts power to the gauges as well as disconnecting power to the field wire to the regulator of the alternator. This does not hurt the alternator. Only disrupting the alternator output when the engine is running and the alternator is charging will damage the alternator.
When my ignition key is off and the engine is running the thermostat is off and will show the temperature about 190 to 200 degrees.
I don’t know why I turned the key off that day but it scared the be Jesus out.
Likes: eherlihy
Sep 28, 2025
112
Stu,
Thanks, that is great information.
I thinking what I did was flipped up the gauge cover to check the temperature and tuned off the key accidentally, seeing the T was high, killed the engine with the throttle and went forward to check the hoses and they were normal temp. Started it back up and went out for a sail.
My engine gauge panel still has some issues after the previous owner swapped out the engine. This is a much more complicated system than I thought at first.
Luckily my alternator seems to be OK. No internal diodes issues yet.
Hope for the best and plan for the worst.
Reagan said, " Trust, but verify".... I say VERIFY first.. Before you jump in and accept the 200º number verify it to be correct. Laser heat guns are inexpensive. Get one, start up and verify the heat at the gooseneck.. IF the gun reads normal, you could be looking at a sending unit replacement. As for your fear of shearing, check around the tool rental places in your area for an induction bolt heater..
Likes: Woodworks1
Jul 5, 2011
771
Oday 28 Madison, CT
Saga continues. The tech installed the thermostat and happened to notice that the raw water pump was dripping from the seal. This is sad because it was new in 2018 swapped out a Sherwood for an Oberndorf and I don’t think we’ve used the boat 50 times since then. Stuff happens I guess. for Depco has 59 on order due for delivery by the end of the year. They can reman mine but I’m not sure I will have it back by Labor Day. It seemed to be pumping quite well, but maybe my eye is not a good judge of whether enough water was coming through. I’ll try running it with the new thermostat and see if that makes any difference, but do I dare risk going out with a dripping pump? Oh, I forgot to mention the tech broke off the temperature sensor and so I’ve ordered a new one, but maybe that’s a good thing. Put Teflon tape on the thread I imagine.
