Was it really easier to run a new wire back to the starter button, than eliminate the harness on your boat?
The reason for going with the super duper "Hunter Booster" is that I didn't have to run any new wires anywhere. It's all the same old dusty 1998 wiring in there. Good Gawd, if I had to install new wiring from the engine back to the starter button, I would have burned the boat to the water line, pocketed the insurance money and walked away. Nothing and I mean NOTHING more could have been run back there without me doing myself a serious injury. Absolutely out of the question
Before we dive into this exercise, only one small thing to remember here, there is an old relay hanging off of the Yanmar called the starter motor relay or just starter relay. This relay is what closes the electrical contacts only to engage the starter motor. It does not turn the starter motor as that takes 187A.
The starter relay is a bit of a bugger and requires about 18A to get it to do its job.
The booster relay (the Super Duper Hunter Booster) is a brand new relay (about $30.00 way back when) you will purchase called a Cole Hersey relay (booster relay for short) and only requires 0.69A to do its job.
Keep this clear in your mind and you've won the battle.
Let me take you through the old 1998 era ignition wiring and show how it kicks the little starter relay into action every time without even half trying. A hundred years from now, when the ignition wiring and the connector is really in bad shape, IT WILL STILL ACTIVATE THE BOOSTER EVERY TIME WITHOUT FAILURE.
Here is the original ignition wiring installed ny Hunter :
It worked when new but as the connector and push button developed a tiny bit of corrosion, the current to the starter solenoid dropped to 17A as I saw on my battery monitor and the starter solenoid lay there dead. When the starter solenoid DID work, it was pulling about 18.5A. 17A no go, 18.5A yes. Not always but enough to piss you off.
Here we have the Cole Hersey relay (booster relay) installed :
The old wiring by Hunter is now required to pass only 0.69A because of the small size of the Cole Hersey relay (booster relay) but the contacts in this small relay are capable of handling up to 80A if the need was there. If the need were more than 80A, the little relay would go up in a ball of fire. The crappy old wire will be able to pass 0.69A for many, many years because the old wire and connection was able to pass 18A at one time and has only developed a small amount of corrosion over ..................... how many years ?
The new wire required is only a couple of feet to reach the booster relay and then away to the starter relay. I erred waaaaay on the safe side and moved the newly added wire up to #12 AWG just to take care of the extra resistance in the additional contacts.
