Bit of a strange request... our H380 came from the factory with a 280L fresh water tank in the bow. That's about enough for 3 of us for 7-8 days with very short showers and being careful with dishes. Thankfully, the stock level gauge, hoooked up the CerboGX has been very accurate once we calibrated the sensor signal to the tank shape.
Even our 31' Beneteau had 2x 200L of water ...
Has anyone increased the onboard water storage? I'm eyeing the stern starboard comparment that was originally designed for a generator (the seat/cover is removable). But that would involve moving the Vacuflush pump to the starboard side and having to build out a shelf...
Alternatively, has anyone found a good spot for a compact water maker? Our starboard settee seats are full (hot water tank, water pump, fridge compressor, 628 Ah of lithium where the AC would normally sit). The port side bench has (stern to bow), start battery, inverter/charger .... the forward most comparment is where we tend to store our food. I suppose a compact watermaker (with 20 in membranes) could fit here, but then where would we put a month's provisions???
The other challenge with a watermaker is you immediately loose 30-60L of what you just made to flush out the membrane (3-5 mins @ 10L/min) .... so If I fill up to 280 L, i'm left with about 230L remaining.
We currently don't have a salt water pump in the galley, but i'm considering it (wash with salt, rinse with fresh). Our vacuflush also uses fresh water, I'm estimating about 2 L / per day (it's nice not to have any smells and the holding tank is good for almost 2 weeks).
Has anyone travelled for 3-4 weeks on these boats without taking on additional water? How did you do it? (I know, people used to cross oceans with 120L fresh water tanks, using salt water for almost everything)...
