Here is a Monty 17 owner in BC with standard winches and cam cleats to hold his foresail.
Her owner, in the cockpit, rigged with a pair of small winch snubbers and cam-cleats. This setup is somewhat affordable (If you can find a #8 or #10 snubber winch at a price under $250, and it is in serviceable condition). It addresses the ideas you query.
The challenge is that Self-Tailing winches are $750 to $1250 a piece, and they are large in size. Your foresails are the size used on daysailers and dinghy racers, 80 to 120 sq ft in area. ST winches are way over-powering for the forces on your sails.
If handling the foresails is causing you stress, why not set up a self-tacking jib?
You may not have seen or even heard of a self-tacking jib before. They’re usually only found on luxury sailboats. But that’s exactly what one is, a headsail that sheets itself when you …
stingysailor.com
You can go as simple or complex as you desire. I always enjoyed the simplest design that was light in weight and affordable on my Monty 15.
Which setup is best?
- Simple daysailing/racing on very small boats → Cam cleats + tracks or fairleads.
- Single-handing or frequent short tacks → Self-tacking track or DIY bridle.
- A bit more power needed → Add a small snubbing or standard winch.
- Want maximum adjustability → Cockpit-adjustable jib cars.
