Swap a Catalina mast for a 14.2 Capri mast
Jun 1, 2026
2
Catalina 14.2 Oyster Bay
Long story short. I snapped my 14.2 Capri mast yesterday (maiden voyage, but in my defense the wood below the step up plate was rotted). Anyway, I am having a hard time finding a replacement 1986 14.2 mast, but have found a 77' Catalina 22 mast. What are the chances of cutting the 22' down to fit? I'm pretty handy, so if it takes a bit of "figuring out" that's ok.
Other than the length, are the dimensions and sections similar? What about the mast weight? Rigging size?
The biggest factor will be weight. If the mast is heavier it will affect the boat's stability making more likely to capsize.
Likes: drcubbin
Jun 1, 2026
2
Yes, I just checked. The 22' mast weighs about 75lbs while the 14.2 weighs about 20-25lbs. Also, the mast length of the 22' is 25', while the mast length of the 14.2 is 22'. Here is my desperation talking... I am thinking I could take 3-5' off of the 22' mast (yes, make it a little shorter) thereby lowering the overall mass. Ok, as I write this it does sound a bit wacky, but if I could get a used 14.2 replacement that would solve all problems. Is it just me or must there be an old 14.2 out there that has a big hole in the hull, but a good mast, that someone just wants gone today?
Thank you for reminding me of the weight and capsizing - once was enough for me. :cool: But there must be a solution somewhere.
Jun 2, 2004
3,670
If the sections are similar diameters go for it. The only issue I can think of is if the 22s mast is much larger and heavier than the 14s you are going to have more weight aloft which aint necessarily a good thing.
Jun 2, 2004
3,670
Old masts are around. It is just a matter of time and effort to find one. You will probably find a boat in better shape someone wants gone looking for the mast.
My wife hates it when a car or a boat follows me home. A few days later she's not mad and I have another toy to play with. When I remind her I could be interested in airplanes or women she is not amused.
  • Ha
So, the 14.2 mast weighs about 1 pound per foot and the 22 mast weighs about 3 pounds per foot. In order to match the weight and and maintain the boat's stability the larger mast would need to be cut down to about 7 feet.
This is all about physics and levers. 1 pound at the end of a 22 foot mast develops a force of 22 foot-pounds. 3 pounds at the end of a 22 foot mast developed 66 foot pounds. That extra force needs to be countered by a broader beam, deeper keel, or increased ballast. This is the really simplified version and does not account for wind speed and sail area.
The bigger heavier mast won't work well and will make the boat more dangerous to sail as it will decrease stability and increase capsize risk.
Jun 1, 2004
8,343
If would be most concerned with the replacement mast's weight, diameter and flexibility. The Cat 22, as well as the 25, 27, 30 were masthead rigged. The spar was very stiff, fore and aft lowers, litterally no prebend. The boats in this class are heavier and do not plane.
The Capri 14.2, however, is a fractional rig with swept back spreaders, no backstay (that I'm aware of). It is a dinghy by nature. Not sure if it will plane, or allow trapezing... it looks more like a lido 14 or holder 14, which are heavier, centerboard type dinghies like your Capri.
So.... I suggest you NOT limit your search to a Catalina vessel, but to any daysailor/dinghy similar is style and weight to your Capri. Check with sailboatdata.com to get your comparable info. There are many boats that fit this category, I'm sure you will find something. All you really need is the replacement mast to have the same mainsail attachment system. Sliders or bolt rope. A bolt rope system will be part of the extrusion. A slider system can be fashioned by attaching a track. If your mainsail uses sliders... start looking for the compatible track pieces (they will be screwed on sections.) Good luck.:cool:
Can't the OP find the original manufacturer or go to one of the remaining mast builders and have one made that fits the boat?
Likes: BigEasy
I would contact Dwyer Mast & Rigging. I suspect they would have the exact match.
If new is out of the budget, check for a consignment shop or salvage yard on the East Coast. They take in old boats and take them apart, selling the pieces. There is bound to be a Capri mast on the East Coast waiting in a yard somewhere.
Look in places where boats get damaged. Hurricane alley from North Carolina to Florida would have potential. Back in the day, the Capri was popular on the Chesapeake Bay.
Likes: BigEasy
May 1, 2012
1
Catalina 42 906 Anacortes, WA
A few months ago, I looked at a 14.2 on the central california coast. Probably too far away for you. The hull was a disaster and needed to go to the landfill. Sitting on a trailer asking $300.
  • Wow
What a find!
The Capri 14.2 was built (5200 of them) in Woodland Hills, CA.
What a road trip opportunity that would be, going home to find a mast.
Jun 2, 2004
3,670
A few months ago, I looked at a 14.2 on the central california coast. Probably too far away for you. The hull was a disaster and needed to go to the landfill. Sitting on a trailer asking $300.View attachment 238083
Road Trip, Baby!
That's exactly what I was talking about.
The trailer would be worth two or three times what is being asked.
Probably could have bought it with two Franklins or five Grants
What a find!
Road Trip, Baby!
Really? Do you think the time and cost of driving from the NYC area to the West Coast and back towing a trailer to obtain a used mast is a worth it?
