Tightening Engine Belt
shank
Apr 20, 2016
133
Catalina 27 5231 Lake Champlain
I made this engine belt tensioner tool I wanted to share in case it helps someone else. I have a Catalina 27 with a Universal 5411 and I could never get the belt tight enough with just my hands. It's just two blocks of wood with holes in one end that the 5/8" bolt sits in. There's a washer on each end and a washer on one end. Just tighten the bolt with the washer to the right belt tension and end then just tighten your alternator bracket. I bought something similar online and it bent and broke the first time I used it. This one is much stronger (and cheaper)
1,905
Oday 31 Redondo Beach
Thanks. That looks almost just like mine. Been workng for me for years.
Likes: shank
Jun 11, 2004
1,905
I probably got the idea from you if you posted it here. I'm too dumb to come with this on my own
It has been a long time but I think I may well have got the idea from someone else here. ;)
This link references an article no longer available from Good Old Boat.
shank
Apr 20, 2016
133
I like how the wood blocks are cut to the shape of the pulleys
Jun 21, 2004
3,093
Beneteau 343 Slidell, LA
Great idea; I am still using the pry bar method for adjusting belt tension.
FYI, if you are interested in acquiring an article from an issue of “Good Old Boat”,
send a request to Sailrite & request a pdf version. Sailrite obtained the entire volume of past issues & will provide a free copy of a given article. Not sure if they plan to archive & index for future availability.
I remember learning to tension an alternator belt watching a Navy LtJg work on his GTO in the 60’s.
When I began to work on my diesel @Stu Jackson was here on SBO sharing insights.
He was using the same spring loaded tensioner tool.
I spent the $15 and used it back in 2015. Only challenge was as I removed the tool half of it dove into my bilge. It is a dark hole that eats tools. During my engine rebuild, I worked to clean the bilge and recovered several long lost screwdrivers, sockets, and the missing half of the tensioner tool.
Fortunately the tool was given a second life in my tool box. Last week I noticed a bit of belt dust around the engine. I grabbed the tensioner tool and adjusted the belt tension. Then adjusted the Balmar regulator belt manager to reduce the alternator output extending the life of the belt
@shank your organic tool is great. Very effective. Thanks for sharing. :beer:
Likes: shank
