I made this engine belt tensioner tool I wanted to share in case it helps someone else. I have a Catalina 27 with a Universal 5411 and I could never get the belt tight enough with just my hands. It's just two blocks of wood with holes in one end that the 5/8" bolt sits in. There's a washer on each end and a washer on one end. Just tighten the bolt with the washer to the right belt tension and end then just tighten your alternator bracket. I bought something similar online and it bent and broke the first time I used it. This one is much stronger (and cheaper)
