Connection of Main Sheet to Sole attachment point
Dec 2, 2025
13
Tanzer 22 ft Lake Winnipeg
Good afternoon!
I'm rigging a new-to-me Tanzer 22. My question is; "what fittings are required to attach the cleat-end of the Main Sheet assemble to the post (with hole) in the sole of the boat"?
I've attached a file of the Mainsheet block (with cleat). the Post in the sole is about 1.25 inches tall .25 in diameter and has a hole through it.
Sorry I never took a picture of the post.
Thank you for any ideas.
Cheers
693
Canel 25 foot Shiogama, japan
If the post is solid you will want a connector that swivels.
Gary
Or this type with a shackle to connect to the becket on the block.
An eye swivel with tow shackles. One to connect to the becket and one to connect to the post
Catalina 34 Casco Bay
Not enough perspective in the photo. More pics necessary.. However, the block shown is a fiddle block with cam cleat..
Likes: Timm R Oday25
Dec 2, 2025
13
I see now, more info is needed. Your insights have prepared me for my next visit to my boat. I think I have a better understanding of what is needed.
Thank you for all your insights and suggestions.
What did new sailors do before the internet and forums existed?!
Thanks again.
I will post an update next week.
Thanks again.
At least for the Tanzer 22 there was a very active Class Association and newsletter full of tips. The glossy mags, Sail, Cruising World, etc had more information and fewer articles promoting the latest charter destination. Practical Sailor was a publication worth reading.
dLj
Mar 23, 2017
5,255
Talk to people that were involved in boating/made a lot of mistakes (not sure this has improved)/figured stuff out by doing...
Not in any way insinuating it was better before. It's way better today. But you do have to sift a lot of wheat from the chafe....
dj
@Dave0963
Is this what your cockpit looks like?
I am a bit uncertain. You are looking for a way "to attach the cleat-end of the Main Sheet assembly to the post (with hole) in the sole of the boat".
I have seen a couple of Tanzer 22's. They either have a cross the cockpit traveler rig or a center cockpit deck post.
Assuming you have a rig like the first image, is there a metal ring on the deck?
Something like this?
Yours may look different, but it functions the same. It is a solid connection to the deck. It needs to have a strong backing plate beneath the deck to spread the load out over the cockpit fiberglass deck (floor).
Then all you need is a strong connection from the mainsheet block to the deck.
A shackle, a soft shackle, or a snap shackle can all be used.
@garymalmgren shows in message #5 a variety of snap shackles. They connect to the mainsheet block and allow you to snap onto the deck padeye.
A nice shackle will also work.
Or if you like lightweight, you can use a 1/4 dyneema soft shackle.
Dec 2, 2025
13
Thank you, everyone!
Your thoughts and ideas are confidence builders.
I was at my boat yesterday and after reading your thoughts my perspective changed. It turns out that the post (more like a pin) on the sole of the cockpit swivels and all that I needed is a couple of D-shackles, which I found at the bottom of the bag the mainsheet was stored in. One d-shackle for the sole and a second for the boom.
Woo Hoo! problem solved.
Thank you again!
Way to go. You are ready to go sailing.:biggrin:
