Hi I have a Yanmar 2YM15 diesel with an SD20 saildrive.
I have had to replace the raw water shut-off valve twice now as it stays stuck in the open position. Each time it is very expensive to haul out the boat and do this for such a small part. I have been told that this should be replaced with a ball-valve type of unit but Yanmar does not make one and still have to haul it out to change this.
In the meantime, I read that I could install and install-line valve between the saildrive and the water pump. It seems if I had the clamps, valve and a plug, I could cut the hose and quickly plug it then do the valve one side at a time without much water intrusion. I really appreciate any thoughts or experience with this. Am I crazy? Also, even if the shutoff worked, this seems like a nice back up to have on board.
Thank you all so much. Please leave out the sarcasm I really appreciate the knowledge out there. Here’s a simple diagram attached
