Hunter Legend 35.5: What should I look for?
Hello All
Tomorrow I am going to look over a 1993 Hunter Legend 35.5. I've been a Hunter owner before and I've owned and restroted many sailboats in my days so.... I'm not looking for generic survey advice...this request is about Unique Properties/Issues with the Hunter 35.5
Can you help me generate a list of known issues that I can look for during my trip tomorrow?
Here is the boat...
Thanks Y'all
RMG
Hey Y'all
This was sent to me as a PM by @jssailem
He didn't feel he could post here because he has never owned a Hunter but... he did conduct an AI dive of various forums and sent me this list.... It reads like a first-rate checklist.
I wanted jssailem to get some credit for going the extra knot... :beer:
Here is his PM to me...
I am not a Hunter owner. I therefore did not post this as an answer to your thread query.
I have read the reviews on Practical Sailor. So I queried AI to develop a list of the issues owners have experienced.
GROK referenced: practical-sailor.com, cruisersforum.com, spinsheet.com, and bolsadenavegantes.net
I noticed that the running rigging showed its age. Sails should be raised and examined. On a 1993 boat, I would require a Rigging survey. My insurance company issued a rider this year on standing rigging that was installed in 2017 because it had not been visually inspected from the top of the mast to the deck this year.
Here is the AI summary report. It might help to establish the base of your checklist.
Specific Issues Discovered by Owners Over Time
The 1993 Hunter Legend 35.5 is a popular coastal cruiser known for its spacious interior and affordable design, but like many production boats from the era, it has developed several age-related and design-specific problems reported by owners in reviews, forums, and surveys. These issues often stem from its balsa-cored deck, fiberglass grid hull reinforcement, wing keel, and certain material choices. Based on owner experiences from sources like Practical Sailor, Cruisers Forum, SpinSheet, and other boating communities, here are the key problems that have emerged:
  • Deck Core Water Intrusion and Delamination: One of the most common complaints is water penetrating the balsa-cored deck, leading to rot, soft spots, and delamination. This often occurs at foredeck fittings, jib furling line exits, chainplate attachments, and around hatches or portlights. Owners report that unchecked leaks can compromise structural integrity around chainplates and rudder interfaces. In surveys of similar models, elevated moisture readings in the deck are frequent, sometimes requiring core replacement (removing soft material and filling with marine-grade core or solid fiberglass).
  • Chainplate and Bedding Issues: Chainplates are prone to corrosion, crevice corrosion, or inadequate bedding that allows moisture ingress. This can lead to leaks into the interior and weaken attachments to the hull's grid system. Some owners note that the inboard chainplates, while allowing for tighter sheeting, exacerbate pumping of the mast in choppy seas due to the lack of a baby stay.
  • Rudder Delamination and Waterlogging: Rudders on older examples often suffer from delamination or becoming waterlogged, reported in multiple surveys (e.g., significant issues in 2 out of 5 boats in one review). The shallow rudder design also limits control when the boat heels excessively or in larger seas, making it feel twitchy downwind.
  • Aluminum Holding Tank Corrosion: The factory aluminum waste holding tank has a short lifespan (typically 10 years max) due to internal corrosion. Many owners have replaced it with a plastic tank to avoid leaks or failures.
  • Wing Keel Performance and Practical Problems: The shoal-draft wing keel (common on these models) is criticized for poor upwind pointing ability compared to fin keels. It also tends to get stuck in mud, kelp, or soft bottoms, and is harder to unstick (heeling doesn't help as it digs in further). Some owners have switched to fin keels for better sailing performance.
  • Portlight and Hatch Leaks/Crazing: Fixed portlights (frameless and recessed) are susceptible to minor leaking and plexiglass crazing over time, leading to interior water damage. Hatches, like the portside lazarette cover, can crack under stress.
  • Hull Grid System Accessibility: The internal fiberglass grid stiffens the hull but makes it difficult to access certain areas for inspections or repairs, especially after groundings or collisions. This design has held up well overall, but it's a frustration for maintenance.
  • Osmotic Blistering: Below the waterline, osmotic blisters (small bubbles in the gelcoat from water absorption) are a recurring issue, requiring remedial repairs like peeling and epoxy barrier coats.
  • Other Systems and Interior Issues:
    • Battery compartment is deep and narrow, making access challenging.
    • Mechanical engine stop (a pull cable) is inconvenient from the helm.
    • CNG stove systems can be problematic due to limited fuel access; many convert to propane.
    • Cabin sole panels can squeak if not securely fastened.
    • Interior trim and veneers may peel or wear cosmetically on high-use boats.
    • VHF and toilet pumping issues have been mentioned anecdotally, though not widespread.
Owners generally praise the boat's light-air performance (3-4 knots upwind in 5 knots of breeze), spacious cabin (with good ventilation from multiple hatches and ports), and value for coastal cruising. However, it's not ideal for heavy offshore use without upgrades, and slamming in head seas has been noted in rough conditions.
What a Buyer in 2026 Should Specifically Examine
By 2026, a 1993 model will be over 30 years old, so expect wear from UV exposure, moisture, and use. Always hire a professional marine surveyor for a thorough inspection, including a moisture meter, haul-out, and sea trial. Focus on these model-specific weak points to avoid costly surprises (repairs like deck core work can run $2,000–$12,000, rudder fixes $1,000–$5,000, and full refits up to $30,000):
  • Deck and Core Integrity: Use a moisture meter to check for elevated readings around fittings, furling line exits, chainplates, hatches, and portlights. Tap the deck for soft spots or hollow sounds indicating delamination. Inspect for any signs of prior repairs or water stains inside.
  • Chainplates and Rigging: Visually inspect chainplates for corrosion, cracks, or leaks. If possible, have them pulled for a close examination. Check standing rigging age (replace if over 15 years) and test for mast pumping under sail. Ensure bedding seals are intact.
  • Rudder and Steering: During haul-out, tap-test the rudder for delamination (solid vs. dull thud) and check for moisture. Inspect bearings for play or wear, and test helm feel in various conditions—note any loss of control when heeled.
  • Hull and Keel: Look for osmotic blisters below the waterline (count and size them). Examine keel-hull joint for cracks or grounding damage. If it's a wing keel, assess for mud/kelp buildup history and consider sailing performance needs.
  • Holding Tank and Plumbing: Inspect the tank for corrosion or leaks; if original aluminum, budget for immediate plastic replacement. Check all seacocks, hoses, and pumps for age and function.
  • Portlights, Hatches, and Leaks: Check for crazing, seals, and leaks. Open/close all to ensure smooth operation. Look inside for water damage to woodwork or upholstery.
  • Engine and Mechanicals: The Yanmar 3GM (24 hp) is reliable, but check hours (under 2,000 is ideal), compression, oil analysis, and exhaust. Test the mechanical stop and access panels. Verify prop walk (minimal with MaxiProp) and cruising speed (5.5 knots at 2,700 rpm).
  • Interior and Systems: Secure cabin sole panels and check for squeaks or access to bilge/sump. Evaluate battery box accessibility and electrical wiring. Test ventilation, head shower (add curtain if missing), and stove (CNG vs. propane). Inspect for cosmetic wear on teak veneers.
  • Sails and Performance Gear: Age of sails (Dutchman system often replaced with lazy jacks). Test in light and moderate winds; reef early (at 18 knots) to assess handling.
  • General Age-Related Checks: Batteries, electronics, pumps, and anchors. Budget for updates like LED lights or chartplotters. Review maintenance logs for patterns (e.g., repeated leak fixes).
Prices for well-maintained examples range $28,000–$45,000, but factor in refit costs. Prioritize freshwater boats or those with recent surveys/upgrades for better longevity.
WADR, to both you and John, the results of an AI search like this one results in issues that could be applied to ANY sailboat of that vintage and general fiberglass construction techniques of that decade.
I have owned sailboats since 1983, the first two of them built in 1981 and this one in 1986. That checklist would apply to the second two which were full keel sloops; the first was a centerboard trailer/sailer. None a Hunter, all Catalinas. Identical issues.
I see nothing exceptional about this stuff. It's generic old boat surveying 101.
@rgranger Since you are moving into the big boat world, you might find Don Casey's book, Inspecting the Aging Sailboat (Amazon link) useful. The book is a bit dated but it covers the major issues when looking at older boats and will go into more detail about potential problems and be more specific than the AI slop you were sent.
Speaking of which, this statement
is inaccurate. Max Props have a very pronounced prop walk, especially in reverse. It does take a bit of practice to master it, but once mastered it allows very precise handling of the boat in tight situations, like docking. I know, I have a Max Prop.
I don't know where GROK came up with this, a 35 foot boat should easily cruise at 6.5-7 knots. My 36' boat easily cruises in that range.
This is just utter nonsense.
I have a wing keel and this has never been an issue. What you should look at is the wings on the keel. Some Hunter models have very thin and easily bent wings. I don't know if the 35.5 is one of them.
If you can, take a friend who has big boat experience with you when you look at the boat. Talk to boat owners about the system issues they have, or just read through the multitude of systems questions on SBO. Small boats are about sailing. Big boats are about managing the various systems.
Good luck on your search.
Likes: Stu Jackson
Rob,
In the description of the boat there are a few red flags that need close inspection by someone knowledgeable.
How old is the Garmin plotter? It may not be possible to update the charts in the plotter due to age. Is it a NMEA 2000 or NMEA 0183 network? NMEA 2000 is an easier network to upgrade and maintain than 0183.
What brand LiFePO4 batteries? How are they installed? Is the installation ABYC compliant? Get independent verification, don't rely on the owner's assessment.
300 watts of Solar is barely adequate for moderate electrical use. We have 300 watts of solar and that just keeps up with daily use on our boat if the weather is OK. The type of solar is also important. Flexible panels mounted on fabric have a short life span. Some brands of panels have higher efficiency ratings and work better in less than ideal conditions.
The ProNautic charger is basically a good charger, except this one is 20a which is way too small for a 460 ah battery bank. It will take about 23 hours on shore power to bring the battery back from 0 SOC to 100% SOC. What kind of alternator does the engine have? The little 55a or 80a Hitachi that comes with a Yanmar engine is not up to the job of keeping a LFP bank charged without damaging the alternator. A 20a B to B charger is mentioned, if the alternator is set up to charge the house bank and this DCtoDC charger is keeping the start battery happy, that's fine. However, since the ad doesn't mention a high output alternator, I suspect the alternator charges the start battery and the house bank is charged by the DC to DC charger. This works for short term cruising or cruising from marina to marina, however it is inadequate for longer term cruising because it will take hours of motoring to charge the battery.
The ad says 100 ft of chain rode, is that all the rode or is it the only the chain section? With only 100 ft of rode the max anchoring depth is under 20 ft. That is very limiting. For reference we carry 140' of chain with 150' of rope.
The stove has been converted to propane from CNG. Close inspection of this installation is critical. Was the stove replaced or were the jets on the burner replaced? When was the conversion done, parts from legitimate suppliers have not been available for over 20 years. Is the propane locker properly vented? Was leak detector and alarm installed? Is the propane hose properly protected from chafe?
How old are the sails? The ad says they are fine, well, maybe.
Again, good luck on your search and for which ever boat you decide to make an offer on, get a good marine surveyor and be there with him during the survey.
If you have more questions, be sure to ask a human who is experienced and knowledgeable.
Likes: Stu Jackson
Please explain this statement. I read that the AI stated “ 5.5knots at 2700 rpm.”
The Practical Sailor review which the AI states as a reference is quoted.
HULL SPEED is identified as 7.31 knots.
It is conceivable that a boat like the Hunter 35.5 with a reported LWL of 29.75ft and a displacement of 13000 lbs could cruise at 5.5 knots
The Hunter Legend is reported to have a Yanmar 27hp 3GM diesel engine. (Practical Sailor) WOT for the engine is reported at 3600 rpm. Running at 2700 would be in the heart of the sweet spot (70-80% of WOT) as stated in many of our SBO forum posts.
The AI is nothing more or less then a collection of data available on the Internet. It is humans who need to validate such gathered data.
5.5 knots cruising sounds pretty low to me too. Our boat with a hull speed of 7.8 knots, 14,400 lbs, and 29 hp engine cruises at 7.1 knots at 75% WOT. Extrapolating that down to the hunter’s hull speed and 27 hp engine I’d expect cruising to be in the low to mid 6’s. Even our previous 28’ boat cruised in the low to mid 5’s
70-80% of WOT doesn’t mean 70-80% of hull speed. This might’ve been what tripped up Grok too. The engine is often sized to get to hull speed with some power to spare for when you’re fighting waves or wind. A 27 hp engine on a 13,000 displacement doesn’t sound too underpowered to me so I would expect it to hit hull speed well before WOT.
If you really believe this then you are deeply mistaken and haven't been paying attention.
Likes: Stu Jackson
@rgranger, congrats! You've needed a bigger cruising platform for decades. As a former owner of a 356 with a winged keel I predict that will be a non issue for you and an asset in your home waters.
Take pictures and please share with us. This is exciting!
Likes: JamesG161
JamesG161
Feb 14, 2014
8,004
Hunter 430 Waveland, MS
AI is collection of knowledge !
It can extrapolate, guess, invent, and predict.
but it still requires HUMANS to operate, maintain and repair it.
Thanks Y'all
Good post @rgranger
Jim...
PS: "Looking for a Sailboat is like a Box of Chocolates, you never know what you get!"
by Forrest Gump
PSS: Of a bad one, "RUN Forrest RUN "
Hey All
Thanks for all the feedback. I took a look at the boat Saturday. It is pretty well maintained. Everything is clean. I was a little surprised at how cramped it felt. Specially after spending so many nights on a Hunter 26. I expected this boat to feel Caverness. The passageway to the aft cabin was tight and I had to turn sideways to get through it, and I couldn’t sit at the dining room table without feeling like any slight heel or jolt of the boat and I would be slamming the edge of the table in my ribs. But other than those two negatives, it was a very nice and impressive vessel.
My 356 had a cramped dining table area. It was a chore to slide in the back. I preferred to drop the table and use the space to throw crap. It wasn’t much good for sleeping either! I see it over and over again on many different designs that the dining area is squeezed in. It’s as if some designer many years ago decided on the size and no one ever re-thought the usefulness of the space. Oh well, we took the overwhelming number of meals in the cockpit anyway. The dining and navigation station are the two biggest waste of space on sailboats!
Boat designers often try to pack as many features as they can in a design often at the expense of actual usefulness. Typically these are production boats and the marketing people focus on dock appeal more than sailing.
Likes: rgranger
Aug 10, 2016
9
Hunter Legend 35.5 Clearwater, FL
Hi Rgranger. I have an '89 35.5 and have just short of 10k nm under her keel since 2016. Here is my take on what has been posted in this thread and my own observations.
The comments about the cramped salon seating area are correct. But it is livable. The flip-up salon table makes it more bearable. We use it all the time.
She doesn't point well for sure. It is a tradeoff to draw only 4.5 feet and again, something we just live with.
A huge drawback is the battery placement down what i call the nutty putty hole. What a terrible design. I got stuck upside down in there once where i kept catching my shoulder blade on the edge as i tried to press myself back out. I was in there for about 20 minutes before finally getting free (many lessons learned there). I have since moved the batteries to the lazarette.
She is the perfect size for two of us cruising the keys for a couple weeks at a time. The step-through transom is amazing for dinghy boarding and swimming. The stern handheld shower is a nice touch.
Her fuel capacity doesn't give her much range, but she is built for coastal cruising. She burns about 0.6gal/hr from my experience. The good news is that there is plenty of space for jerry cans.
The discussion about speed under motor are dependent on bottom cleanliness. You can really tell the difference with a freshly cleaned bottom. When she's slick, she makes 6 knots at around 2200-2300 rpm. I never rev her more than 2500 because you just don't have to. Note that at 6kts, she makes a little gurgle sound as the water comes around the stern. I keep her to mid-6's while under sail to give her some breathing room for gusts and weather changes and she is very comfortable at that speed.
She is set up well to single hand. I do it all the time and its terrific. The only thing i wish is that there was a good place to mount a wind vane. Eventually I will sacrifice some aft deck space for one, but there isn't a good place for it without cluttering up the stern and interfering with boarding the dinghy and general swimming from back there.
My biggest criticism is that I refer to her as "corky" in confused seas. Compared to some other similarly sized vessels it is not a comfortable ride for sure. She will toss you around when the weather is rough out in the open water.
The biggest win for me and it offsets the pointing issue is that she handles amazingly well while docking. Very, very responsive and can turn 180 degrees almost within her own length. When backing her into a slip, she handles even better. That is worth her weight in gold to me.
I hope you get as much joy from her as we still do ours.
jm
@24jmanley
Thanks for the first-hand review. I am not convinced that this is my boat but I am keeping her on my list of possibles. I am very certain that the Admiral will insist that my next sailboat be my "forever" boat so... I am going to take my time.
Probably pure fantasy and certainly impractical but I also have a soft spot for the Nor'sea 27 center cockpit model. Here is a pristine example
  • Wow
@24jmanley
Now there is a sailor who likes to varnish. Beautiful, but lots of work.
  • Ha
Likes: rgranger
