DIY Sailing Instrument
Sep 13, 2015
61
Catalina 22 Eugene
A few years back I built a wind instrument and I've been using it for years now and really appreciate its functionality.
Here is a picture of it on my Catalina 22:
This first version was somewhat difficult to build and the software took me quite some time to get to where I was happy with it. I do have the original Arduino C++ code and I was about to try and compile it again to dig into fixing a problem with my setup when I found out that all the libraries had been updated and I remember there was an incompatibility I had to modify the libraries to make them work and it was just more hassle than it was worth.
So instead I'm deciding to do a new version of the wind instrument. This version will still be using Adafruit hardware but I'm going to redo things using an RP2040 based Adalogger rather than the M0 that was used in the first version. I'm also planning on replacing the Alphanumeric display with an OLED feather that also comes with buttons. Then I'm redesigning the case so that you can use Adafruit's breakout boards that I used in the first version with out soldering and adding connectors near as much.
I'm planning on simple instructions on how to build one but it should require fairly little soldering (if you can solder 0.1" headers that is all about all that is really required). Then you 3D print the case and heat set brass inserts into the plastic case. then the boards screw into the case and plug together... As I finish the first one I'll take pictures and show how it goes together. I hope to have the software done by this Summer but so far I have a working menu that drives the buttons and display on the OLED. Once I get more hardware I'll get the LEDs going and bring on real sensor data (right now its just random data).
Any interest in this or am I the only one? I'd say its going to cost about 300 dollars for a system including the anemometer. But I'm probably forgetting pieces... Its still cheaper than the big box marine guys who are usually well over a grand for a full system and they don't have the weather sensors.
Here is a picture of what the new version is looking like at the moment in the current mechanical design:
I do also have a NMEA based system on my other boat and I'm considering making an NMEA2000 flight recorder black box that basically does the GPX logging portion of this project but without the display. I'll be doing that open source as well stored here: https://bitbucket.org/Brett-Howard/bthblackbox/src/main/
Sounds pretty interesting. What are you using for the anemometer? When I was looking to build my own wind sensor finding a good option there was the hardest part.
Sep 24, 2018
4,448
Catalina 30 MKIII Chicago
Looks good so far. You weren't kidding when you said there's very little soldering. I'm about to build an LED dimmer controller because I can't find anything that's simple and easy to use.
Sep 13, 2015
61
Catalina 22 Eugene
I am using this one in the Marine Grade fashion from Peet Bros. I bought this for the V1 version of the wind instrument and that part of things I believe is still working just fine. If you really dig into their design its just 2 magnetic reed switches and its very elegant in how simple the anemometer is. The only pain is that its a bit difficult to decode the pulses into speeds and directions but Peet Bros actually helped there and provided algorithms to get wind speed for their anemometer. They're still made to this day as well which is why I chose them the first time.
Really great products and I even broke the first one cause I'm an idiot. I had it setup on a photography tripod in the back yard for debugging and a gust of wind knocked it over and it smashed into the ground. Upon telling the company about this they simply sent me a new one free of charge. So pretty awesome people too!
Sep 13, 2015
61
Catalina 22 Eugene
I'm also curious what anemometer is used, as these tend to be expensive.
Sub-$300 wind instruments with transducers exist commercially: Clipper Wind System V2 w/Masthead Transducer & Cover
Mark
Yea I'd looked at this one a while back... But I wanted to be able to do the environmental sensors and the GPS and I wanted the trip logging functionality for my log book too. I'm a nerd and I keep a paper log and having this instrument has made my log much more accurate and a lot less lick my finger and guess...
I should add that their solution has a major advantage to mine in that its actually water proof. With the SD card interface on and the USB-C opening and the buttons and all I don't think that I could come up with a good way to seal it up and make it water proof... But I'm also not really all that skilled in that type of design either so maybe once done if I put my mind to it I could grow in that area and come up with something.
That’s good to know. I already have an NMEA sensor on my mast, but I’ve been wanting to build a wind sensor that could be mounted on one of our club’s race marks. We have a mark that’s far enough from land to get clear air, but close enough to our clubhouse that I think I could get signals from it with a LoRa radio.
Likes: Timm R Oday25
Sep 13, 2015
61
Catalina 22 Eugene
I've set things up on the first wind instrument to have the mast head end at fairly low power because its got a fairly small solar panel. On a more substantial tower than a mast you could probably give a lil more solar or transmit less often and increase the power a bit. I bought the LoRa stuff cause I wanted to play with it and ended up playing with it less than I thought I would. So I really should probably use the cheaper packet radios but for exactly solutions as you mention David the LoRa just seemed like it would be a fun option. You could probably also install a better antenna on a real tower as I just manually cut antennas out of some coax soldered to some u.fl connectors.
Which if I want to try and make this simple for people to build I should probably find an off the shelf antenna for these now that I think about it.
Sep 13, 2015
61
Catalina 22 Eugene
I have a small LED that I use as a night light that comes on automatically in front of the head door on my bigger boat and I needed a way to dim that LED down. I just wanted a simple PWM controller with a knob and I found this to be adequate for that need: https://www.amazon.com/dp/B073R7H52B
Not sure if it works for your need but since I'd fairly recently used that and it worked for my needs I figured I'd share.
Sep 13, 2015
61
Catalina 22 Eugene
I should also add... I've got an NMEA2000 wind instrument on the mast of my bigger boat and thus I wanted to add the GPX trip logging to the larger boat but I've already got a full NMEA2000 setup on that boat. So I'm hoping to do a black box flight recorder type project where I'll just have a box with a single NMEA cable coming out and it'll have a micro SD card in it that will start logging all the NMEA2000 data that it can to the card whenever you leave your slip location. That way you can use a GPX application and see a map of your trip but you can also click on any datapoint on the trip line and see the wind speed, water depth, vessel attitude, whatever you want or more to the point whatever you have available on the NMEA network.... I'll probably start on that one when I hit a slow spot on the wind instrument... The code for it will also be open source and found here: https://bitbucket.org/Brett-Howard/bthblackbox/src/main/
colemj
Jul 13, 2004
1,036
I don't believe you mentioned it doing all of that in your original post.
Is there a reason you don't have it mounted to see from the helm? Or is that position in view of the helm?
Mark
Sep 13, 2015
61
Catalina 22 Eugene
Mark
Yea it does a lot that I've not mentioned quite yet... But that stuff is what the old instrument does and the new instrument I don't have the code done yet so I don't want to go spouting things it can do until it can do them....
But this has barometric pressure and temp sensors as well as a full 9 DOG IMU. So it can indicate heel and it can use all of its sensors to give you a compass and it can calculate true wind and show you that by subtracting out the boat's movement. It also will give you statistics at the end of your sail such as average wind speed, average wind direction, max heel angle... And then all of these stats should get written into a folder for the year and then inside of that folder will be GPX files that when opened can display a map of every trip you've taken and you can click on the track to see more information about the state of the vessel at that time.
I have it setup where you write you home slip location into the SD card in the text file and then when you leave that location it starts collecting stats and when you get back to the slip it locks things down and writes a record into a CSV file that at the moment matches the format of the manual logbook I pictured above.
The real hope and dream is that I get this thing done enough to be functional by summer... Then I'll setup the auto pilot and toodle around on the lake while I think of new features and try to implement them before I get to the other side of the lake. hehe.
Oh and yes that location inside the boat can be easily seen from the helm position through the companionway (if you helm from port). Now that I think about that I may need to add into the menu some brightness settings cause the last version of this had an ambient light sensor and it set the brightness of the display automatically based on sensed levels.
The first version used a gesture sensor that you waved your hand in front of it from top to bottom or bottom to top or left vs right... The theory was that I was going to be able to seal things and shoot the IR from that sensor through a plastic window. Turns out in the end getting that sensor to go through a window without just light piping through the plastic was near impossible. So I had to cut a hole to let the light out. Then the user Karate Kid user interface as I called it was good enough for me but flaky enough that I was the only one who could use the instrument. Thus why this version is just going back to normal buttons.
I’ve done something similar but putting the metrics into KML instead of GPX. With KML you can see the data in Google Earth, and click on each point to get more details like you said.
Sep 13, 2015
61
Catalina 22 Eugene
I thought about using KML but found that GPX was more generic and worked in a lot more tools and Google Maps could open a GPX as well and would then save out a KML if I wanted it. Is there a benefit that you found by using KML over GPX? I remember considering them a while back when I did the first version of this and decided to use GPX but if I made the wrong choice I'd be willing to use the other format...
I wrote the script to assemble the KML about 10 years ago. At the time I didn't know GPX could hold more metrics than just the locations. KML was just the first thing I saw that would work the way I wanted. Certainly could be that GPX is the better option now.
Likes: brett_howard
Sep 24, 2018
4,448
I have a small LED that I use as a night light that comes on automatically in front of the head door on my bigger boat and I needed a way to dim that LED down. I just wanted a simple PWM controller with a knob and I found this to be adequate for that need: Amazon.com
I actually used that exact model to dim down my insanely bright stern light. Flying insects were following us everywhere at night!
I have a motion sensor for the head
Shortly after I ordered several components I found the Skydance RK1 controller and V1K PWM dimmer. It's wireless so I'm not surface mounting wires next to the companion way, it's a simple rotary dial with push on/off. It's self explanatory and easy to use in the dark. I might still add a 1 min delay to keep the lights on after the batteries are turned off. It's helpful when you forgot something
Sep 13, 2015
61
Catalina 22 Eugene
Motion sensor is a decent idea... I so far have just replaced all the old fixtures with LED based replacement bulbs. I kinda like the old brass fixtures and once I replaced the old pink bulbs where all the red was wearing off with full real red LEDs the night mode looks WAY better now.
Also that RK1 controller is pretty slick looking.
capta
Jun 4, 2009
5,066
I'm sorry, but I just couldn't read through all that tech stuff. What are you using for your transducer, is it cabled and where is it mounted.
A suggestion, if not already discussed; is there a dimmer switch? I've had many bits of electronics, almost before the word was coined, that were just too dammed bright to have in front of me on a night watch. For my 10' Garmin Gpsmap I had to get some stage lighting gel and cut it to fit on the screen, to dim it enough for us to see over it in the dark.
Of course, for those who consider curling up under the dodger as doing their night watch, then I guess it wouldn't be that much of a problem.
Sep 13, 2015
61
Catalina 22 Eugene
https://www.peetbros.com/shop/item.aspx?itemid=137 Anemometer is from Peet Bros I've had one on my C22 for years now and it still works well. Also its still for sale which is very nice!
Yes it has a brightness setting! I'm very much a night owl and I'm writing a good bit of the software in a pitch black room and if it couldn't get dim I'd hate it. The first version of the instrument had an ambient light sensor and would auto adjust based on brightness that it senses. But this one won't have that so I'll probably just have a menu setting for brightness and a red background mode for night maybe.... Really this goes on the lake boat and I rarely use the wind instrument after dark so its not much of a worry for me but I do get that its very important.
On the big boat out of Newport, OR night watch is a constant look out for crab pots... No curling up and hoping you're nearly guaranteed to pick up a pot. Thankfully it's MUCH less stressful when the motor is off.
