My '98 H-376 Salon Window has a vertical, through & through, hairline crack. Any suggestions for a repair, so I do not have to replace window?? Possible to seal crack with an epoxy, or other material ?? Many Thanx, MRF
You MAY be able to repair it with clear Dow Corning 795. But it will look lousy. 795 is silicone and I know the purists around here are starting to groan, "Oh my God, silicone on a boat. NEVER"Possible to seal crack with an epoxy, or other material ?? Many Thanx, MRF
Dow 795 and the standard hardware store and marine store silicons are different critters. If the silicon smells like vinegar, don't use.You MAY be able to repair it with clear Dow Corning 795. But it will look lousy. 795 is silicone and I know the purists around here are starting to groan, "Oh my God, silicone on a boat. NEVER"
Got bad news for the purists but your production boat (Cat, Hunter, Bene, Jenny, etc) has a heavy load of DC795 on its exterior as a sealant / adhesive on the frameless hatchlights and portlights.
If it is cold, then the two sides have contracted and pulled apart. When it is warm again, they will expand and go back into contact and you can weld them together then.WOW !! THANX ALL, for the timely and astute replies. My Post was an afterthought the other night of the day whence I discovered the crack. There is a micro-space between sides ( light can be seen through it from the inside ) so I guess the fusion suggestions might not be feasible?? It's freezing here currently, so I'll send pictures once it warms up so I can visit the boat. Essentially, it's a vertical crack the whole height of the pane. It isn't noticeable from outside. I discovered it when I was raising the window blind....saw a sliver of light. Again, Many Thanx. MRF
Not exactly. If the crack has not yet penetrated the glass, placing a rounded groove of a Dremel going to the bottom of the crack, will reduce the stress, not raise it.Do not grind a groove into the acrylic, as this will greatly weaken the window and act as a stress riser.
Give them a call.Dave, You are correct that replacement IS the best solution. I looked on HSBO website but did not find Salon Windows. Any other suggestions for a source?
The OP stated the crack has penetrated through.Not exactly. If the crack has not yet penetrated the glass
Correct me if I'm wrong but the reason sealants fail is due to lack of elasticity and due to that, the adhesion fails. So in theory, a stronger adhesive might fair better if more elasticity is not an option?Do to the large stress across the glass ( <--- x --->) you will need a sealant, not an adhesive, which will move with the annual compression and expansion.
A better way to think of this is not "lack of elasticity" rather insufficient elasticity for the application. Rubber bands break when stretched because they have been stretched too far. Same with elastic caulks, a thin bead of caulk will have a more restricted range of motion than a thick bead of caulk.Correct me if I'm wrong but the reason sealants fail is due to lack of elasticity and due to that, the adhesion fails. So in theory, a stronger adhesive might fair better if more elasticity is not an option?
I did not realize that sealants can lose elasticity with age. This explains a lot. I have a friend who's VERY knowledgeable when it comes to boat repair. He's stated that silicone is fine for bedding so long as the fitting doesn't move much. I've always been skeptical of his use of silicone but what you said backs him up.A better way to think of this is not "lack of elasticity" rather insufficient elasticity for the application. Rubber bands break when stretched because they have been stretched too far. Same with elastic caulks, a thin bead of caulk will have a more restricted range of motion than a thick bead of caulk.
The other issue is many sealants lose elasticity with age and that can cause them to fail because they won't stretch as far. Butyl tape does not do this, they remain elastic for decades.
The problem with most silicones is poor adhesion, this is especially true with marine silicones and hardware store silicones. There is a category of architectural silicones, like Silpruf and Dow 795 which have both good adhesion and elasticity. If the silicone smells like vinegar it won't have good adhesion.I did not realize that sealants can lose elasticity with age. This explains a lot. I have a friend who's VERY knowledgeable when it comes to boat repair. He's stated that silicone is fine for bedding so long as the fitting doesn't move much. I've always been skeptical of his use of silicone but what you said backs him up.
Thank you for this info. Ok now back to the issue of the cracked window
Which is exactly what Hunter did in later models when they split the large forward window into two pieces with a narrow FG separator in between the two windows. Shorter windows = less thermal stress.split the window and use the center frame as a structural edge for both pieces,
