I've just bought a1974 22' Tanzer with a poor electrical system (no fusing, lots of tape, wire nuts and abandoned wires). I've used the ABYC Tables for ampacity and done the calculations for Voltage Drop and Derating for bundled wires, given conductor length and temperature ratings of the insulation.
The kicker motor is a pull start, so there is no electrical for an engine and also there is no provision for shore power. I will add a solar charger at a later date tied directly to the Pos and Neg Buses.
A question I have not been able to resolve is regarding fusing. I believe the fuse size is a function of the conductor size, ie the fuse is intended to protect the conductor. Many sites suggest selecting the size of the fuse to protect devices. From an electrical perspective, I don't see a safety issue with using an "undersized" fuse. Can anyone provide insight on the matter or a snippet of the ABYC Electrical Code that addresses use of fuses.
I have attached a copy of my Schematic and Panel Directory, is it appropriate to ask for input on my design?
I've tried to keep my Branch circuit ampacities low (below 2 amps) where possible to decrease voltage drop. I believe 14 awg is required for the Anchor light and also for the VHF (transmit ampacity is large).
Thank you for any and all feedback.
